SPD Android - How To Solve Google,Patten,Pin,ETC & Hang On Logo Without Debag & Flash SPD Android Tutorial How To Solve Google, Patten, Pin, ETC Lock & Hang On Logo Without Usb Debag Enable & Without Full Flash 1st You Need :
Q: I need backup From Same phone ? A: If you have same phone , That Better Q: I don't have same phone Also don't have same Backup , I can Use any Backup ? A: Yes You can But Better If you use same Company Phone , If Dont Have You Can Use Any One Same Company Example - If your lock phone is Qmobile So Use Qmobile Backup , If Lava Use Lava , If Micromax Use Micromax , If Symphony Use Symphony Backup Note - If You use Same Phone Backup Then You Can Solve 100% without Any Problem Q: Its Risky ? A: I Already Do But Not Dead , Not hang On Logo . But Better If You Take Risk Q : Did You try It With Other Phone Backup ? A: Yes . I did . See Here : http://forum.gsmhosting.com/vbb/f723...bahar-1756415/ How to Crate This File (PAC Or RESET File ) : MostImpotent http://img5.imageshack.us/img5/6425/8zk1.png Must Be Flow It , On Gide Have Little Mistake Open ResearchDownload.exe Now Click To Setting http://img89.imageshack.us/img89/467/gqps.png Now Unmarked All Select File ,Select Your Chip & Select Baud Rate http://img826.imageshack.us/img826/2526/v484.png Now Select FLD1 , FLD2 & UserData File http://img809.imageshack.us/img809/1714/0htj.png FLD1 , FLD2 & UserData Select Done . See UserData Marked , Its Must Be Mark http://img585.imageshack.us/img585/6982/aylq.png Now Click to Packet & Click Yes http://img31.imageshack.us/img31/6334/n8y6.png Again Click Yes http://img855.imageshack.us/img855/6351/ydga.png Select Product Version (File Name) , Saving Pach & Click Ok http://img856.imageshack.us/img856/664/wkq4.png Your PAC File Crate Done http://img31.imageshack.us/img31/2769/y9hh.png Now You Can Flash With This File http://img35.imageshack.us/img35/1217/3ut3.png Brhttp://forum.gsmhosting.com/ubb/wink.gif One-Man ..::AzimBahar::.. |
How To Flash With PAC File : How To Flash SPD Android With ResearchDownload : Note -You Need Use ResearchDownload_R2.9.7006 Because Other Version Given Error http://forum.gsmhosting.com/ubb/wink.gif
This Phone Done With Other Phone Backup Because That Time I Dont Have Same Backup See Here Tested Report : http://forum.gsmhosting.com/vbb/f723...5/#post9974806 Note - Some Time You Get Error On reserchDownload After Write User Data File , Dont Worry ;) Your Phone Is Ok Already Just On Phone & Do reset From Setting Note - Always After Flash Do Reset From Setting http://img35.imageshack.us/img35/1217/3ut3.png Brhttp://forum.gsmhosting.com/ubb/wink.gif One-Man ..::AzimBahar::.. |
i try this solution but not working i am try some userdeta file but userdeta size error http://forum.gsmhosting.com/vbb/f728...y-one-1755074/ |
You Did with ResearchDownload ? Its working & tested My Me . I Do maximum Post After Tested , Without test i dont like post Br;) AzimBahar |
is there any universal file for all spd sets with same cpu ? |
@...gsmsikar Yes brother i already use 1 Phone backup In another Phone & Its Work But You must use in same Chip , I mean if your File Is 6820 So You can Use In Another 6820 Phone Kindly Before Try Read Full Thread Br;) AzimBahar |
hi about 1st You Need :
thk |
After backup you will get All file , you only you nees FDL1,FDL2 & USERDATA File Br;) AzimBahar |
HI, USE Script Backup, i had make the backup. but don't have FLD1 AND FLD2. HOW TO MAKE PAC? B.R. LIKI. |
@...LIKI Yes its Not backup FLD1 & FLD2 Check here details - Spreadtrum SC6820/SC8810 Full Backup - xda-developers & For create PAC file , You need edit file , After You Can Do details - Spreadtrum SC6820/SC8810 Full Backup - xda-developers Br;) AzimBahar |
please help for my cd-r king a1 phone..if anyone have firmware backup for this i need your help...tanx :) |
Need pac files for my spd android tab...restarting only after try to flash 2mb pac file.... when i try to read info via volacano... it say says no partition found |
thk for ur help, now in my case the phone is dead in formated by volcano. How do , it can t light, refuse to on in recovery mod for root it . need help,. forever i have another on which work fine. plz, thk |
Can u make a video tutorial for this? |
sir volcano box 2.4.4 version setup open karne pe invalid opretion aata hai aur setup open nahihn hota hai bahut pareshan hai plz help sir |
