09-08-2016, 04:38 | #21 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2099356 Status: Offline Thanks Meter: 15 | Dial *#*#83781#*#* Under Telephony Tab , scroll down & select Set IMEI... Then reboot phone.. Tested on Advan Vandroid S7 (SC7731G).. |
The Following 15 Users Say Thank You to Dynamise For This Useful Post: |
09-17-2016, 15:03 | #22 (permalink) |
No Life Poster Join Date: Dec 2008 Location: GUJARAT-INDIA
Member: 926215 Status: Offline Sonork: 100.1650776 Thanks Meter: 95 | My problem is critical i have karbonn a109 spd7715 model and i flashed it via flash tool after that a i see different type of imei may be changed with new firmware so...there is no network in phone and i checked imei ...with sim imei is null and without sim imei is ok ...after that i write genuine imei (back sticker) imei write success but problem is there still....any idea ?? 1 imei is ok without sim 2 imei is null when sim is inserted in phone |
09-23-2016, 13:24 | #23 (permalink) |
Crazy Poster Join Date: Jul 2009 Location: kadapa,andhra pradesh
Member: 1071407 Status: Offline Sonork: 100.1646176 Thanks Meter: 23 | Dear Friend, Use This Version IMEI Write Tool : WriteIMEI_R3.0.0001. Open Tool & Feel Both 15 Digits IMEI Then Click On "Write", Press & Holding Volume Down Key Insert USB Cable Then Insert Battery. Note : All Process Need To Do With In 30 Seconds, Otherwise IMEI Tool Stop & Need To Feel IMEI & Click On Write Again. Don't Release Volume Down Key Until You'll See "PASS!" & Green Color In IMEI Tool. https://drive.google.com/file/d/0B4x...ew?usp=sharing |
The Following 5 Users Say Thank You to kadapafriends4u For This Useful Post: |
10-29-2016, 07:32 | #25 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2083746 Status: Offline Sonork: [email protected] Thanks Meter: 1 | thanks... its work for , sc8830 |
02-19-2017, 20:19 | #30 (permalink) |
Junior Member Join Date: Sep 2013 Location: Jabalpur ,M.P. india Age: 29
Member: 2016089 Status: Offline Sonork: 100.1669830 Thanks Meter: 2 | Tested With LAVA Iris 400Q Miracle Report - Unsuccessful Tool Report - Successful (IN SINGLE TIME) Thank you so much Last edited by .:SARCAR:.; 02-20-2017 at 08:54. |
The Following User Says Thank You to ashutosh00074 For This Useful Post: |
