Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones > Android based chinese phones
Old 12-04-2016, 16:49   #136 (permalink)
Member: 2402412
thank you for quick answer, I just want to flash TRWP "recovery.img"
I have also this error message when I put the recovery file out of scatter file folder
Old 12-20-2016, 17:15   #137 (permalink)
Member: 2607815
Sonork: 100.16758955
Thanks Meter: 44
sp flash tool brom error (5000 solution
Old 12-26-2016, 19:35   #138 (permalink)
Member: 1850349
i got error code (4010) while flashing tecno p5 with sp flash tool and wiselink
Can someone please help with a way out please?
Old 01-02-2017, 23:23   #139 (permalink)
Member: 2500904
Sonork: 100.1612890
Thanks Meter: 29
Sp Flash Tool Brom Error HUAWEI LUA U22 and all in all mtk ic support 100% working tool https://drive.google.com/file/d/0B_6...ew?usp=sharing
The Following User Says Thank You to gsmsohel1234 For This Useful Post:
Old 01-07-2017, 15:00   #140 (permalink)
Member: 452260
Thanks Meter: 36
Sumsung sm-j700m 5.1.1
Hello,
This is for information:
SUMSUNG SM-J700M 5.1.1
Model: SM-J700M
Not recognized by odin.
Efectively it is a clown, it and recognized by SP Flash Tool.
I am flashing with SP Flash Tool v5.1352.01 for this device. But never dealt with successfully. Although I used the MT6589_Android_scatter_emmc, I had a previous backup of the other similar device. If running on a blinking red bar reaches 100%, always an error with the message: BROM_ERROR: S_DL_GET_DRAM_SETTING_FAIL (5054).
But still there is no way I can get to blink on the device. Here are the steps I made flashing with tools:
1. Turning off and disconnecting the battery from the devices (I also tried to blink with the battery but failed)
2. Connect the USB cable to the peripheral devices (but not to the PC)
3. Installing the USB VCOM Driver for MTK MTK6589
4. Run the Flash SP tool and enter the Scatter file
5. Click the "Download" button on the SP Flash Tools
6. Connect the USB cable from the peripherals to the computer
7. Look at the process of blinking the computer screen occurs.
Initially there is a process with a red bar marks. The device driver is also detected (see in Device Manager). When the bar reaches 100% in red, the device is detected by the DA USB VCOM port (COM 17). But immediately displays a BROM_ERROR error message: S_DL_GET_DRAM_SETTING_FAIL (5054) and the blinking process has failed.
Is there a way to restart my device? . I really need your help.
Old 02-22-2017, 14:23   #141 (permalink)
eyobaaa's Avatar
Member: 2102546
Thanks Meter: 480
Originally Posted by chandanps18 View Post
Here are a few more list of errors and solution
1] BROM ERROR : S_FT_ENABLE_DRAM_FAIL (4032) [EMI] Enable DRAM fail
Cause: SP Flash tool is unable to enable DRAM / communicate effectively with the device
Solution: Ensure that the file(s) you're trying to flash are actually for your exact phone model
Format the phone before trying to flash the file(s) again
Ensure the phone is switched off (with battery still inside) before connecting to PC for flashing.
If that doesn't work, keep trying with the boot key
2] BROM ERROR : S_DL_PMT_ERR_NO_SPACE (5069)
Cause: The size of a file is larger than the available / possible partition size.
Solution: Ensure that the file(s) you're trying to flash are actually for your exact phone model. Try another stock ROM
3] S_FT_Download_Fail(4008)
Solution: Fully Charge the battery. Use the latest SP Flash Tool. If still u get this problem, time to format the device. Note: in format Your all data e.g Nv data will be deleted...
The thread will be updated.
Wbr
Chandan
i got this error BROM ERROR : S_DL_PMT_ERR_NO_SPACE (5069) even i trying to write it's own backup scatter file.... where did this error come from
Old 02-27-2017, 09:51   #142 (permalink)
Crazy Poster
Member: 2617092
Thanks Meter: 3
Micromax A37B Flashing Error
Micromax A37B Flashing Error..
Broom Error:S_FT_NFB_DOWNLOAD_CODE_FAIL (4014)
Please Help me ....
Last edited by ...:::::NP™:::::...; 09-05-2017 at 14:14. Reason: Image link correction
Old 03-06-2017, 08:50   #143 (permalink)
Member: 2622063
Sonork: hahahahaha
Thanks Meter: 2
Hello you will make your contribution on this subject: 2] BROM ERROR: S_DL_PMT_ERR_NO_SPACE (5069)
Cause: The size of a file is larger than the available.
Solution: Ensure that the file (s) you are trying to flash is actually for your exact phone model. Try another stock ROM ... I have a clone of samsung galaxy Grand Neo plus Gt-I9060I but I already try several rom but I still have an alert message S_DL_PMT_ERR_NO_SPACE (5069) I'm already exhausted help me sorry.
The Following 2 Users Say Thank You to yvane For This Useful Post:
Old 03-07-2017, 04:53   #144 (permalink)
Member: 2577930
i need help for sptools
can i flash custom rom with sptools,using stock rom scatter file,
Old 03-22-2017, 11:37   #145 (permalink)
best_s_gsm's Avatar
Member: 240499
Thanks Meter: 151
mtk flash tool error
can you helpme thanks
Old 03-23-2017, 07:44   #146 (permalink)
Member: 2438247
Sonork: N/A
Oh i ned help for m-horsh note5 lost imei which tool can i use to flash it
Old 04-01-2017, 04:22   #147 (permalink)
Member: 2701736
Hello
Phone : Inew L4
SPtool message error : S_INVALID_BBCHIP_TYPE (0x3EB)
Have 3 different ROM versions tested on two different Inew mainboards.
What is the solution ?
Thanks Stefan
Old 05-07-2017, 05:21   #148 (permalink)
Member: 2469357
Thanks Meter: 8
Sir my handset micromax hang on logo when flash it gone dead when I flash again with format all flash done but still dead when I firmwere upgraded it give get pmt info fail please give solutions
Old 05-10-2017, 04:16   #149 (permalink)
Member: 2469357
Thanks Meter: 8
This problem is flash file please change another file
Old 09-05-2017, 07:28   #150 (permalink)
Member: 2617843
Sonork: no idea
Thanks Meter: 13
micromax a190 soft da not responce 4001 is there any solution...
Page generated in 0.26271 seconds with 10 queries
