Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones > Android based chinese phones
Old 01-14-2015, 16:36   #16 (permalink)
Member: 1284488
Sonork: jhay
Originally Posted by Abussabah View Post
"BROM ERROR: S_FT_DA_NO_RESPONSE (4001) DA didn't send response data to FlashTool! "
what this error.....?
micromax A110, mt6577
Sabah Mangattupulam
india
(4001) S_FT_DA_NO_RESPONSE
Change USB-port and transfer SP Flash Tool in the root of your main harddrive ( C: )
Also there is maybe no info in the file download agenton the CPU / flash. Solution - upgrade.
The problem could also be hardware, such as broken flash memory.
The Following User Says Thank You to jhay_19 For This Useful Post:
Old 01-26-2015, 07:55   #17 (permalink)
Member: 2335063
Sonork: 1650895
Thanks Meter: 10
Old 02-03-2015, 01:14   #18 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,225
is this emmc problem or firmware problem ?
Old 02-03-2015, 02:03   #19 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,225
Old 02-03-2015, 07:28   #20 (permalink)
Moderator
gsm mithun roy's Avatar
Member: 1537689
Sonork: 100.1669550
Thanks Meter: 2,086
maybe emmc damage but same thing happen if phone don't have emmc chip only nandchip ..
The Following User Says Thank You to gsm mithun roy For This Useful Post:
Old 02-03-2015, 13:11   #21 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,417
this error come when ur set have NAND flash chip and u try to write emmc flash file
check again ur flash file
The Following User Says Thank You to sneha For This Useful Post:
Old 02-03-2015, 14:15   #22 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,225
So where i get flash file for this model ?
Old 02-03-2015, 15:44   #23 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,417
modle ??? cpu ???? need more info for help
Old 02-03-2015, 23:41   #24 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,225
I9500 clone single sim mt6572 not connected with sptool
Old 02-04-2015, 08:59   #25 (permalink)
Moderator
Member: 1537689
Sonork: 100.1669550
Thanks Meter: 2,086
1st things about your phone its with nand chip no emmc
you trying emmc firmware will not work
2nd as sp tools not detecting you have driver problem [or you bricked its not detect in pc ] check
if detect then fix driver issue or try to another pc
Old 02-04-2015, 10:49   #26 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,225
Already try many drivers, set is detected by pc ,the main thing if i want to flash this phone than where i get the file for this and how to solve drivers issue , may be u r right ,pc searching for drivers and after minutes show failed unplugged device
Old 02-04-2015, 11:21   #27 (permalink)
Moderator
Member: 1537689
Sonork: 100.1669550
Thanks Meter: 2,086
use another pc or try fresh windows
we use xp s3 is batter for driver solve
Old 02-05-2015, 12:32   #28 (permalink)
Member: 1741973
Thanks Meter: 110
what about sp flash tool PMT change for the ROM, it should be downloaded
Old 02-09-2015, 12:45   #29 (permalink)
Member: 2322288
Arrow
BROM ERROR : S_FT_NFB_DOWNLOAD_CODE_FAIL (4014)
Fail to download image(s) to NAND flash!
How to solve ?
model: Intex aqua 3g
chip: mt-6572
sp tool - SP_Flash_Tool_exe_Windows_v5.1436.00
Old 02-10-2015, 07:34   #30 (permalink)
Moderator
Member: 1537689
Sonork: 100.1669550
Thanks Meter: 2,086
How to solve ?
chip: mt-6572
you already flashed wrong file to this phone ..!
The Following 2 Users Say Thank You to gsm mithun roy For This Useful Post:
Page generated in 0.42158 seconds with 8 queries
