12-04-2013, 09:46 | #1 (permalink) |
Freak Poster Join Date: May 2009 Location: Bangladesh
Member: 1024699 Status: Offline Sonork: 100.1622959 Thanks Meter: 600 | Symphony W16 Pattern Lock Done. Step2.Press Volume up button then press Volume Down u will see android logo (No command) Step3.Press power button Step4.Volume down select wipe data/factory reset then Press Volume up and do job (Select Button Volume up) IF U Like My Post Only Press Thanks....... |
The Following 2 Users Say Thank You to SRASHED For This Useful Post: |
09-21-2014, 10:06 | #2 (permalink) | |
Junior Member Join Date: Nov 2009
Member: 1155149 Status: Offline Thanks Meter: 3 | Quote:
09-21-2014, 11:37 | #3 (permalink) |
No Life Poster Join Date: May 2010 Location: BANGLADESH Age: 43
Member: 1306751 Status: Offline Sonork: 100.1604993 Thanks Meter: 4,916 | Symphony W16 3G Hard Reset or Restore Factory Settings [IMG]http://3.bp.********.com/-0cIYRbzX-og/U6JvoaFI-TI/AAAAAAAAAZ8/TJOi8zQiVw8/s1600/W16_3.5_White_0711+-+Copy+%282%29+-+Copy-600x500.jpg[/IMG] To Reset your phone by button just follow the instructions………. 01. Turn your phone off. If it is in frozen mode or in hung mode then remove the battery and insert it after a few seconds. 02. Press and holdVolume Up/Down + power until power is on with a menu including “Android system recovery”. 03. Use Volume Up/Downto scroll and use menu/camera/power/volume up to select. 04. Select “wipe data/factory reset” from the menu. 05. Select “Yes…clear all user data”. 06. When the “wipe data/factory reset” is completed, then select “Reboot system now” and wait for restart your phone. |
The Following User Says Thank You to helpful-man For This Useful Post: |
