05-26-2014, 12:48 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Anwar Telecom .DHAKA Age: 38
Member: 896667 Status: Offline Sonork: 100.1586139 Thanks Meter: 1,596 | symphony w80 flash & imei problem !symphony w80 dead flash this file W80_8548_V000025/W80_WCDMA_V000003_3 and mobile run but imei /0 network no service how to write Qualcomm cpu imei any one help me |
05-26-2014, 12:54 | #2 (permalink) |
No Life Poster Join Date: Aug 2012 Location: MUMBAI-METRO Age: 37
Member: 1800009 Status: Offline Sonork: 100.1654307 Thanks Meter: 806 | IMEI Writer_Prem_India write with this |
The Following User Says Thank You to mobite For This Useful Post: |
05-26-2014, 13:18 | #5 (permalink) |
Banned Join Date: Jul 2011 Age: 32
Member: 1609044 Status: Offline Thanks Meter: 892 | Installing BP driven phone turned on, insert the data cable, the computer will prompt the discovery of new hardware. Installing BP part of the drive, selected after extracting Drive / USB Modem Driver/Win32 manually install the driver, a total of up to three times, each time selecting this directory. Windows 7 users select Install this driver software! After installation is complete, there will be a computer device manager modem and two ports: (beginning with Tianyu HS-USB devices), please remember this modem port 3.IMEI write numbers unzip downloaded to Qualcomm_Modem_Tools_V1.1.rar, open the run Qualcomm_Modem_Tools.exe. Check Device Manager --- confirm the port modem: Modem COM Port: Fill above the port modem IMEI: Enter the need to write in the box IMEI number, and click Write to begin to write numbers. When Write imei Pass! When writing numbers represents success! ! Finally, read the IMEI number to confirm the next. Complete |
The Following User Says Thank You to gsm_mithun For This Useful Post: |
05-27-2014, 08:02 | #7 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | The W80 is the K-Touch W806+ Hornet, based on MSM8225 and is a GSM-WCDMA phone You can check the collection of qualcomm Tools for k-touch mobiles available on the support Welcome to the ./downloads/K-Touch/Qualcomm Serie/Qualcomm Tools/ folder of GsmHosting support area BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
05-27-2014, 08:29 | #8 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | more infos about recovery and the imei can be found in the tool folder of the videocon A30 if needed (Always on gsmhosting support area) : This mobile have the same processor and even a qualcom recovery procedure for the bootloader is available inside. BR Alex |
05-27-2014, 09:48 | #10 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | the second imei should be the wcdma one. About the network, in the modem tool, you should get a .txt file with the calibrations BR Alex Note : you can try as well the karbonn A9+ and A21 IMEI tool as have the same processor too http://support.moulnisky.com/index.p...s/Imei%20Tool/ Last edited by moulnisky; 05-27-2014 at 09:51. Reason: Note added |
11-15-2015, 19:01 | #11 (permalink) |
Freak Poster Join Date: Dec 2011 Location: bd lkpur raipur
Member: 1708706 Status: Offline Sonork: 100.1605514 Thanks Meter: 36 | i need solution..Symphony W80 flashing.... Symphony W80 EMMC DownLoad flashing after "serial comm port" change "human interface device" dont boot for volcano. how to change it human interface device to comm port......any ways |
The Following User Says Thank You to mobile_media For This Useful Post: |
