10-10-2013, 11:52 | #1 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Little apt called Alhambra
Member: 13748 Status: Offline Thanks Meter: 84 | Weird SP Flash Tool issue Just in case someone had the same problem in the pass and knows how to solve it. I´m trying to unbrick an Umi X1S with mt6589. I have correct drivers, SPFlashTool and ROM, but... here comes the issue with flashtool: After click on download (firmware-update) red bar starts and goes to 100%, then simply do nothing more, the greyed buttons comes alive like if has finish with the task but clock keeps running. The only thing I have noticed is that after the red bar if you reconnect the usb it changes from regular MTK or Mediatek usb vcom to Mediatek DA Usb Vcom Port. Things I tried: Different ROMS All SP Flash Tool V3.13xx versions I´ve found (1304,1308,1312,1316) Connect phone with battery, without battery, pressing different buttons, etc... no luck in anyway. Different drivers Thanks in advance and BR |
10-10-2013, 12:32 | #3 (permalink) |
Member: 13748 Status: Offline Thanks Meter: 84 | thx for reply I tried with 3.1320 and 1328 Payload means download agent? I tried with all agents in the folder without success, the only agent that make something different is MTK_AllInOne_DA_SW_SEC_BOOT.bin that reports: BROM ERROR: S_USUPPORTED_VER_OF_DA (1022) Any other advice? thx and br |
10-10-2013, 15:12 | #4 (permalink) |
No Life Poster Join Date: Nov 2002 Age: 43
Member: 17689 Status: Offline Sonork: 100.72392 Thanks Meter: 737 | it means someone or you have flashed the handset with completely different cpu soc or config or diff PMT so only solution is TESTPOINT search for KIO(i dont remember the name correctly) testpoint in pcb touch it to the GND and put usb cable and flash correct firmware it will accept the 2nd loader for sure |
The Following User Says Thank You to yousha For This Useful Post: |
