Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones > Android based chinese phones
Old 04-17-2013, 07:41   #61 (permalink)
Member: 1803535
Sonork: 100.1601678
Thanks Meter: 17
how to remove paternlock spdturm cpu
Old 04-18-2013, 09:06   #62 (permalink)
fahad ali khan's Avatar
Member: 1771086
Thanks Meter: 2,388
how to write imei Coolsend ic .........
Old 04-19-2013, 22:10   #63 (permalink)
Member: 441426
Hardware : SMDK4x12
Model : GT-N7100
Build number : JRO03C.N7100ZSALIA
Build date UTC : 20130304-072924
Android v : 4.1.1
Baseband v: MAUI.11AMD.W12.22.SP.V17, 2012/11/28 12:38
Kernel v : 3.0.31-178067 (se.infra@SEP-113) (gcc version 4.4.3 (GCC) ) #1 SMP Mon Mar 4 15:27:41 CST 2013
Please help me, my new phone become invalid imei after reset.
Thank you in advance.
Old 04-19-2013, 22:54   #64 (permalink)
Member: 905956
thank you..whats the password plz..
Old 04-23-2013, 14:32   #65 (permalink)
Crazy Poster
Member: 1804513
Sonork: 177.17.69.69
Thanks Meter: 5
This is fake tool it not working i know password
It is not working
Old 04-29-2013, 06:49   #67 (permalink)
Member: 750201
i need password plz
Originally Posted by ashakaass View Post
thanks.... admin , my acount is now open....
can u give me password plz
Old 05-02-2013, 21:30   #68 (permalink)
Member: 494220
Smile pass
new trik by ashakaas, write imei mtk android no box, no rx tx,no need root ,use usb only
very simple , iam sory iam bad englis
tool n tutorial by ashakaas
tested mtk 6516,6577,6575,6573...........next...............
download
or
download
pm to reguest password or ym ashak_aas
brother,password,thenks by ricardao
Old 05-03-2013, 09:46   #69 (permalink)
Member: 651811
tenk
Old 05-08-2013, 11:10   #70 (permalink)
Member: 117514
PM pass bertapa boss
Old 05-15-2013, 14:31   #71 (permalink)
Member: 80456
Thanks Meter: 7
password is
SUKSESBERTAPASEHARISEMALAM9990123
Old 05-15-2013, 18:00   #72 (permalink)
Member: 80456
Thanks Meter: 7
Restoring your IMEI
Edit: Since it is now often used, and proven, method 5) at the bottom may be the preferred method
Edit2: And now the new Droid Tools (method 6) is an even nicer tool. In fact, it may be so good, it is not just the last, but the final Mediatek tool. See below.
Method 1) Use RootExplorer to copy back that backup MPOB_001 file from your external SD card into folder /data/nvram/md/NVRAM/NVD_IMEI/. (or if that folder does not exists, maybe /nvram/md/NVRAM/NVD_IMEI/.)
Afterward, set permissions to 0660 or rw-rw----
Method 1b) You can also generate your own MPOB_001 file on a PC, using this set of programs created by some clever russians called f_mulder & pvsurkov, and copy that file to above location. Generate using these commands on a PC:
imei.xxx <15digit_IMEI_1> <15digit_IMEI_2>
. Restore this file as mentioned above in Method 1)
Method 2) Restore using Mobile Uncle utility (actually, that did not work for me)
Method 3) Install a cli terminal app, for example Android Terminal Emulator, and enter these commands:
(replacing IMEI_1 and IMEI_2 with the actual IMEI of course). Please take care, the Android keyboard will constantly try to change the commands you are typing into 'proper' English spelled words. Ensure the commands are as shown below.
su
echo 'AT +EGMR=1,7,"IMEI_1"'> /dev/pttycmd1
echo 'AT +EGMR=1,10,"IMEI_2"'> /dev/pttycmd1
Method 4) If you have ADB running, the same as above, from windows adb:
(replacing IMEI_1 and IMEI_2 with the actual IMEI of course) If you do not know what ADB is, then never mind, easier to use 3) above or 5) below.
adb shell
su
Method 5) Install this mt6516imei.apk app, and enter your imei numbers in there, and press write.
The reason I list this option last, even though it is the easiest, is because the program was never finished. Only the 'write' button works. While working on it in 2011 my PC crashed and I lost the source, so I never completed it. So again, only the Write button works!
But its enough, and at moment of writing, 3 people have used it on their phones, two reported success (the 3rd never reporting anything, so I assume it worked for him too, because if it had failed I am sure he would have complained).
NIEUW: Method 6) User rua1 of the russian forum made a very nice PC utility. You do need the drivers for the phone installed, but MTK Droid Root & Tools can read and re-write, amoung other, the IMEI for Mediatek phones. If you have working drivers, this is now the prefered method I guess, my half-finished app demoted to when you can't get the drivers.
If you do use this tutorial or its 'barely a program' attachment, please leave a response, and if you know how to find the IMEI-2 on your model phone, post it clearly below. Thanks!
Old 05-15-2013, 18:27   #74 (permalink)
Maik_TechService's Avatar
Member: 846968
Sonork: 100.1613167
Thanks Meter: 138
Invalid or Deleted File. what next?
Old 05-16-2013, 07:35   #75 (permalink)
Member: 80456
Thanks Meter: 7
password is
The Following User Says Thank You to kmpatel For This Useful Post:
Powered by Searchlight © 2016 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.34275 seconds with 8 queries
