07-20-2014, 19:53 | #1 (permalink) |
Freak Poster Join Date: Oct 2008 Location: BANGLADESH Age: 36
Member: 885431 Status: Offline Thanks Meter: 80 | All China mobile mt625a & mt6260 cpu dead solution 100% tested Frist chack by power supply If sence show only 2 Don't worry No need flash No need format No need hit by hot air gun Just connect charger & wait some time then show charging bar then Perss powre switch & wait for phone on Otherwise press power switch long time then power on It's only solution for this problem No other's solution now Last edited by Parash; 07-21-2014 at 17:35. Reason: Mobile number removed |
The Following User Says Thank You to masudd For This Useful Post: |
08-09-2014, 19:18 | #6 (permalink) |
Freak Poster Join Date: Jun 2008 Age: 36
Member: 794428 Status: Offline Thanks Meter: 80 | Any brand china mt625a,mt6260 cpu phone if dead Frist chack by power supply If sence show only 2 Don't worry No need flash No need format No need hit by hot air gun Just connect charger & wait some time then show charging bar then Perss powre switch & wait for phone on Otherwise press power switch long time then power on It's only solution for this problem No other's solution now Last edited by Parash; 07-21-14 at 22:35. Reason: Mobile number removed The Following User Says Thank You to masudd For This Useful Post: ateeq797 07-23-14, 15:23 #2 (permalink) jhoker23 Junior Member Join Date: Jul 2014 Posts: 2 Member: 2216899 Status: Offline Thanks Meter: 0 china tablet a13 no power i press power button volume up not working 07-30-14, 11:11 #3 (permalink) Sayantan9933 Junior Member Join Date: Jun 2014 Posts: 1 Member: 2209902 Status: Offline Thanks Meter: 0 Tnxxxx ...........helpfull thing Yesterday, 22:38 #4 (permalink) gsm_sujan Freak Poster Join Date: Nov 2011 Location: sylhet;bangladesh Age: 23 Posts: 263 Member: 1691448 Status: Offline Sonork: 1619100 Thanks Meter: 19 lol i have done dis problem may b 5000up set......u r right but 1000% solution rehot full set thn set 100% oky Today, 00:17 #5 (permalink) babumnmm Freak Poster Join Date: Jun 2008 Age: 26 Posts: 118 Member: 794428 Status: Online Thanks Meter: 16 change only chirging point Bookmarks Digg del.icio.us Quick Reply Message: Options Quote message in reply? « Previous Thread | Next Thread » Posting Rules You may post new threads You may post replies You may post attachments You may edit your posts BB code is On Smilies are On [IMG] code is On HTML code is Off Trackbacks are On Pingbacks are On Refbacks are On Forum Rules Forum Jump All times are GMT +6. The time now is 00:12. Contact Us - GSM-Forum by zfrank - Archive - Top Powered by Searchlight © 2014 Axivo Inc. vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd. - GSM Hosting Ltd. - 1999-2014 - Page generated in 0.81080 seconds with 12 queries SEO by vBSEO chirging point problem 100% tested |
08-09-2014, 19:19 | #7 (permalink) |
08-14-2014, 08:43 | #8 (permalink) |
Freak Poster Join Date: Dec 2012
Member: 1851477 Status: Offline Sonork: 100.1641475 Thanks Meter: 101 | wash or change only charging jack for all new mobiles hange or keypad problems |
The Following 2 Users Say Thank You to asifmobilestec For This Useful Post: |
09-07-2014, 18:50 | #10 (permalink) |
No Life Poster Join Date: May 2010 Location: BANGLADESH Age: 43
Member: 1306751 Status: Offline Sonork: 100.1604993 Thanks Meter: 4,916 | Rehot resoldering not perfact solution it's temporary solution better solution 1st rebole ic after problem not solve replace this bad ic maybe solve your problem |
09-07-2014, 19:13 | #11 (permalink) |
No Life Poster Join Date: Dec 2008 Location: bangladesh
Member: 926902 Status: Offline Sonork: 100.1655575 Thanks Meter: 517 | i have only this perfect solution this type problem name is i called appendices problem just cut 2no pin near ground .then no hang no on problem all ok |
