01-30-2016, 09:04 | #31 (permalink) |
Major Poster Join Date: Dec 2013
Member: 2095243 Status: Offline Thanks Meter: 0 | |
02-03-2016, 06:53 | #32 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | in this case i always use bin file via Some Profession Tool but in mostly cases bin file not available so be careful while using scatter file and make sure that file is tested before br cal_phon Last edited by MyGSM World; 04-02-2016 at 11:34. Reason: Box Name Removed. |
02-24-2016, 20:06 | #33 (permalink) | |
No Life Poster Join Date: Oct 2006 Location: pakistan
Member: 373786 Status: Offline Sonork: 100.1601935 Thanks Meter: 130 | Quote:
i just done one mobile same problem just download correct file it will be alive | |
04-02-2016, 06:32 | #36 (permalink) |
Junior Member Join Date: May 2014
Member: 2192826 Status: Offline Thanks Meter: 1 | hello guys i have a solution for this i tried for many scatter files now i found the solution....open SP Flash Tools, turn download speed to "Full Speed" and "W/O Battery", turn cable on, took battery out and in again, flash process starts and went till the end. |
The Following User Says Thank You to lhetmakuz01 For This Useful Post: |
04-05-2016, 18:50 | #37 (permalink) |
Freak Poster Join Date: Jun 2012 Location: Jamaica Age: 39
Member: 1769612 Status: Offline Sonork: 100.1626332 Thanks Meter: 24 | 1000000%%%% Fix Just write memory with the scatter file that you downloaded with firmware and then run flash again. Worked on multiple devices |
04-15-2016, 01:53 | #38 (permalink) |
Freak Poster Join Date: Jun 2005 Location: EGYPT Age: 53
Member: 157001 Status: Offline Sonork: 100.1585825 Thanks Meter: 45 | sm-g7102 Dear friends I have sm-g7102(clone) vietname and i have flashed it with a wrong firmware now it is dead so would you please can any one help me with the correct firmware and also i want to know how i found the correct firmware of it thx in advance |
04-22-2016, 10:21 | #39 (permalink) |
Major Poster Join Date: Jan 2014
Member: 2101647 Status: Offline Thanks Meter: 9 | if you have a CORRECT back up flash file of your phone.you can try to format the whole flash except bootloader.use flash tool latest version.this solution worked for me twice. |
The Following User Says Thank You to Munyazmobitec For This Useful Post: |
07-30-2016, 09:17 | #41 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2534499 Status: Offline Thanks Meter: 2 | hi everyone i solved this problem just by flash the preloader of the corect firmware its simple check the cpu model of device and firmware be the same br |
The Following User Says Thank You to mehdito For This Useful Post: |
08-16-2016, 15:32 | #42 (permalink) |
No Life Poster Join Date: Dec 2008 Location: GUJARAT-INDIA
Member: 926215 Status: Offline Sonork: 100.1650776 Thanks Meter: 95 | I have face this error 4032 in micromax a110q and i download 3 different type of firmware but i got same error so if you have a firmware of this model please share model : Micromax a110q cpu : Mtk6589 h/w:ver:v1.1 s/w:ver:v16 |
09-11-2016, 04:36 | #45 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1219273 Status: Offline Thanks Meter: 0 | I have also micromax a104 canvas fire phone and exactly that problem and not solve I am sure my firmware is correct becouse i am flash another same model with same flash file I think is a hardware problem becouse customer says that phone is damege by fall down |
