06-19-2014, 00:01 | #1 (permalink) |
No Life Poster Join Date: Aug 2012
Member: 1792561 Status: Offline Thanks Meter: 78 | 'BROM ERROR : S_FT_ENABLE_DRAM_FAIL(4032) issue? i notice most mediatek cpu like 6275.6577 6570 while flash come this error 'BROM ERROR : S_FT_ENABLE_DRAM_FAIL(4032) i hear then set parmanent damage. too many experts have in this forum. they not reply. what is this issue? if someone have solution please help us. |
The Following User Says Thank You to ajmal786 For This Useful Post: |
08-17-2014, 15:01 | #2 (permalink) |
Freak Poster Join Date: Feb 2006 Location: in ur soul
Member: 234349 Status: Offline Thanks Meter: 227 | hi it can be repairable if u format with correct preloader error 4032 is thats means u have flash wrong preloader now seach correct frimware first format whole flash then flash |
The Following User Says Thank You to sayyedikram For This Useful Post: |
09-01-2014, 14:08 | #3 (permalink) |
Crazy Poster Join Date: Jun 2006 Location: St. Vincent and the Grenadines
Member: 296925 Status: Offline Thanks Meter: 18 | i had a same issue with that error and even i format, it gives same error. |
The Following 2 Users Say Thank You to totolzz For This Useful Post: |
10-06-2014, 20:41 | #6 (permalink) |
No Life Poster Join Date: Feb 2010
Member: 1228709 Status: Offline Thanks Meter: 268 | This error is because PRELOADER inside flash that you want to flash is not compatible with your phone. Solution = Download correct firmware |
The Following 3 Users Say Thank You to JorgeVla For This Useful Post: |
11-05-2014, 19:55 | #7 (permalink) |
No Life Poster Join Date: Feb 2003 Location: africa Age: 54
Member: 22284 Status: Offline Thanks Meter: 81 | hi how to know the correct pre loader ,like in my case I know the fone is Galaxy Siii min I8190 ,MT6572a with the pic board attached |
The Following User Says Thank You to chitawira For This Useful Post: |
11-06-2014, 00:59 | #8 (permalink) |
Freak Poster Join Date: Nov 2007 Location: SUKATANI-BEKASI-APAC_X
Member: 624037 Status: Offline Sonork: 100.1608764 Thanks Meter: 41 | Please share the solution. Firmware from backup, any version of sptool, not work. Sent from my BlackBerry 9220 using Tapatalk |
The Following User Says Thank You to Syifa.Cell For This Useful Post: |
11-10-2014, 08:35 | #9 (permalink) |
Freak Poster Join Date: Dec 2006 Location: philippines
Member: 407557 Status: Offline Thanks Meter: 102 | So easy to say download the correct firmware but what if you are sure you have the correct firmware but still have the same error ??? |
The Following User Says Thank You to knives143 For This Useful Post: |
12-23-2014, 15:06 | #11 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Iassy Age: 59
Member: 19723 Status: Offline Thanks Meter: 359 | explication is simple. i have many hours loose on this problem with chinese phone lenovo. you send a loader to the phone with configuration mapping of your memory address. if the settings from loader is not correct the phone don't responding because you knock on wrong door. you can't put any firmware on phone because software in phone are sign with cryptographic key. sure we don't have the key to unlock firmware. the only solution is to download all firmware you find and send loader to phone until you find one correctly. happy new year! |
The Following User Says Thank You to usernome For This Useful Post: |
01-18-2015, 07:16 | #13 (permalink) |
No Life Poster Join Date: Mar 2013 Location: Nepal Age: 41
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | most or problams are from nand flash and emmc chip, if all fails in software then try to reball emmc chip or nand/nor chip. tested by me many tilmes. |
The Following 2 Users Say Thank You to KE6SOLTI For This Useful Post: |
03-13-2015, 09:39 | #15 (permalink) |
Major Poster Join Date: Mar 2014 Location: Philippines
Member: 2141040 Status: Offline Thanks Meter: 17 | I have now S5 G900F CPU type MT6572, problem stock on logo i tried hard reset but still stock on logo so i decided to flash ang sad to say i encounterd this big issue. Can any one help me? please post your solution. TIA! |
The Following User Says Thank You to abnoy01 For This Useful Post: |
