Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones > Chinese Phones Hardware Repair
Old 08-01-2013, 08:00   #1 (permalink)
sandeep56's Avatar
Member: 699762
Thanks Meter: 66
How to REPAIR network problems
There is two sections in network
1) Rx section.
2) Tx section.
All technicians need to use manual searching in mobile phone, testing for Rx section and Tx section.
* * * * * * * * * * HOW TO FIND WHICH SECTION IS FAULT Tx (or) Rx ? * * * * * * * * * *
Testing Rx section : -
Use manual search for Testing Rx section, after searching Rx section good condition means it shows network list like Airtel, Hutch, (or) any other network list in your area,
If Rx section bad condition after searching it shows NO NETWORK FOUND
1} After searching it shows network list means Rx section is OK.
2} After searching it shows NO NETWORK FOUND means Rx section is FAULTY.
Testing Tx section : -
Use manual search for testing Tx section, after searching it shows network list, then you can choose your simcard network, if Tx section is good condition it shows HOME NETWORK SELECTED, if Tx section is fault it shows NO ACCESS.
1} After selecting network it shows HOME NETWORK SELECTED means Tx section is OK.
2} After selected network it shows NO ACCESS means Tx section is fault.
--------- Information of Rx section components and ics nokia dct-3 tech ---------
1] Antenna switch
2] RF IC ( Hagar IC )
3] AUDIO IC ( Cobba IC )
4] Crystal oscillator
5] Filters
6] VCO ( Voltage Control Oscillator )
--------- Information of Tx section components and ics nokia dct-3 tech ---------
1] PF IC (PA IC)
--------- Information of Rx section components and ics nokia dct-4 tech ---------
1] Antenna switch
2] Filters
3] RF IC ( Hagar IC )
4] Crystal Oscillator
5] VCO ( Voltage Control Oscillator )
6] UEM IC
--------- Information of Tx section components and ics nokia dct-4 tech ---------
1] PF IC (PA IC)
********* HOW TO REPAIR Rx SECTION FAULT ? *********
----- Solution for Rx section no network found fault nokia dct-3 technolagy -----
1] Clean the pcb well and Rehot ( If not OK follow one by one solutions )
A) Give antenna switch jumper
B) Rehot the RF IC
C) Rehot the AUDIO IC
D) Reball the RF IC
E) Change the RF IC
F) change the AUDIO IC
G) change the crystal oscillator
----- Solution for Rx section NO NETWORK FOUND fault nokia dct-4 technology -----
1] Clean the pcb well and Rehot ( If not ok follow one by one solutions )
B) Reheat the RF IC
C) change the crystal oscillator
D) Reball the RF IC
E) change the RF IC
F) Change filters
----- Solution for Tx section NO ACCESS fault nokia dct-3 technolagy -----
A) Change the PF IC
----- Solution for Tx section NO ACCESS fault nokia dct-4 technolagy -----
A) Change the PF IC
----- SOLUTION FOR OTHER NETWORK FUALT -----
1] Solution for low network coverage, all models
A) Give jumper from antenna contact to cabinet antenna
B) change the antenna switch
----- Solution for dct-3 technology -----
When switch on the mobile it shows full network after few seconds its goas down
1] Flash the phone - Rebuild IMEI - Clear UI settings ( If not OK follow 2nd solution )
2] check the track from battery + ve point to PA IC, if track is ok then change the good PF IC.
----- Solution for dct-4 technology -----
1] write good pm file (If not OK follow 2nd solution )
2] change the PF IC, if still the problem same check the PF power track to battery + ve point.
The Following User Says Thank You to sandeep56 For This Useful Post:
Old 08-01-2013, 08:12   #2 (permalink)
Member: 656277
Thanks Meter: 187
1) Rx section.
2) Tx section.
1] Antenna switch
5] Filters
1] PF IC (PA IC)
1] Antenna switch
2] Filters
6] UEM IC
1] PF IC (PA IC)
B) Rehot the RF IC
D) Reball the RF IC
E) Change the RF IC
B) Reheat the RF IC
D) Reball the RF IC
E) change the RF IC
F) Change filters
A) Change the PF IC
A) Change the PF IC
bro. it's chinese section plz cheq before any post
The Following User Says Thank You to nitish1 For This Useful Post:
Old 11-16-2014, 05:35   #3 (permalink)
Member: 2267232
I have a problem in xolo 600s mobile, in mobile antena pad and some of the track are removed by mistake so how i repair network section
Old 12-08-2014, 16:53   #4 (permalink)
Member: 1071128
Thanks Meter: 33
very good info
but this is china mobile section
not nokia
Page generated in 0.14855 seconds with 8 queries
