china mobile charging problem when insert charger "warning bad contact charger" |
Change charger and select right charger. If not work change charger port. |
that problems come some times whit some chinese phones... Options to fix : #1- re-heat whit hot air the IC power charge #2- Buy 1 Diode is 5v to 4.7 rectify is a cristal diode whit red paint remove the Power IC charger and put the diode on pin 1 to 6.... If you don't know about repair phones, send to the seller for warranty |
all phone not show this message for same problem. so, when you make a post, must post details info about your phone and problem to get quick and perfect reply. |
sir i have also problem with china sigmatel brand s90 WARNING BAD CONTACT CHARGER pls quick solve my pronblem thanks advance for help |
you can check the charger cable whit tester multimeter the red ( + ) and the black ( - ) if are any problem the tester will help you to fix.... |
Hello, Any body have E6180 manual. I installed PC suite and driver but not able connect with PC suite. Also I am not able connect in GPRS. Please help |
good news for chaines problem for bad charger just direct fuze and enjoy |
very good brother good news for chaines problem |
thanks for this solution i need image soliution pls |
pl post pic sir by chaina mobile pcb |
chaina xkesstel model x100 bed contect charger problem plz help me |
Wings 108 mobile charge not store.when charger pluged in after the two step of battery charge it do not take charge althuugh it show charge.please reply immidiate.. |
plz me wating................ |
sir i have china mobile who did not save the charging but show the charging pls help me plsssssssssssssssssssssssssssssssssssssss. |
