Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones > Chinese Phones Hardware Repair
Old 09-28-2008, 14:38   #1 (permalink)
Elias Khan's Avatar
Member: 724951
Thanks Meter: 37
china mobile charging problem
when insert charger
"warning bad contact charger"
The Following 7 Users Say Thank You to Elias Khan For This Useful Post:
Old 09-28-2008, 19:34   #2 (permalink)
eafta's Avatar
Member: 489876
Thanks Meter: 277
Change charger and select right charger.
If not work change charger port.
The Following 4 Users Say Thank You to eafta For This Useful Post:
Old 09-29-2008, 08:07   #3 (permalink)
teknospc's Avatar
Member: 852415
Sonork: 1606874
Thanks Meter: 218
Originally Posted by Elias Khan View Post
when insert charger
that problems come some times whit some chinese phones...
Options to fix :
#1- re-heat whit hot air the IC power charge
#2- Buy 1 Diode is 5v to 4.7 rectify is a cristal diode whit red paint
remove the Power IC charger and put the diode on pin 1 to 6....
If you don't know about repair phones, send to the seller for warranty
The Following User Says Thank You to teknospc For This Useful Post:
Old 09-29-2008, 10:06   #4 (permalink)
Moderator
tkowsar's Avatar
Member: 233205
Thanks Meter: 4,865
when insert charger
all phone not show this message for same problem.
so, when you make a post, must post details info about your phone and problem to get quick and perfect reply.
The Following 5 Users Say Thank You to tkowsar For This Useful Post:
Old 12-09-2008, 11:34   #5 (permalink)
Member: 366275
Thanks Meter: 13
sir i have also problem with china sigmatel brand s90 WARNING BAD CONTACT CHARGER pls quick solve my pronblem
thanks advance for help
The Following 5 Users Say Thank You to arjun_anjna For This Useful Post:
Old 12-10-2008, 03:23   #6 (permalink)
teknospc's Avatar
Member: 852415
Sonork: 1606874
Thanks Meter: 218
you can check the charger cable whit tester multimeter the red ( + ) and the black ( - ) if are any problem the tester will help you to fix....
The Following 3 Users Say Thank You to teknospc For This Useful Post:
Old 12-27-2008, 16:17   #7 (permalink)
Member: 925249
Hello,
Any body have E6180 manual. I installed PC suite and driver but not able connect with PC suite. Also I am not able connect in GPRS. Please help
The Following User Says Thank You to iqbal_md For This Useful Post:
Old 02-05-2009, 09:16   #8 (permalink)
fazi52's Avatar
Member: 904326
Thanks Meter: 59
good news for chaines problem for bad charger just direct fuze and enjoy
The Following 2 Users Say Thank You to fazi52 For This Useful Post:
Old 09-05-2009, 06:25   #9 (permalink)
Member: 1047794
Thanks Meter: 4
very good brother
The Following User Says Thank You to gulshan6534 For This Useful Post:
Old 09-05-2009, 07:08   #10 (permalink)
Member: 1101535
Thanks Meter: 3
thanks for this solution i need image soliution pls
The Following 3 Users Say Thank You to jothikrish For This Useful Post:
Old 09-28-2009, 06:37   #11 (permalink)
Crazy Poster
Member: 715238
Thanks Meter: 20
Options to fix :
pl post pic sir by chaina mobile pcb
The Following 2 Users Say Thank You to radeyshyamSHYAM For This Useful Post:
Old 02-13-2010, 08:12   #12 (permalink)
Member: 218021
Sonork: mizandnj
chaina xkesstel model x100 bed contect charger problem plz help me
The Following User Says Thank You to mizan For This Useful Post:
Old 10-19-2010, 15:59   #13 (permalink)
Member: 676855
Wings 108 mobile charge not store.when charger pluged in after the two step of battery charge it do not take charge althuugh it show charge.please reply immidiate..
Old 10-25-2010, 18:01   #14 (permalink)
Member: 352880
Sonork: 100.1609545
Thanks Meter: 534
Options to fix :
have u any pic of this solution
plz
me wating................
The Following User Says Thank You to master mobiles For This Useful Post:
Old 01-19-2011, 17:51   #15 (permalink)
Member: 1496982
sir i have china mobile who did not save the charging but show the charging pls help me plsssssssssssssssssssssssssssssssssssssss.
6300 china phone charging problem Gordak_air Chinese Models & Cloned Phones 11 06-21-2010 14:52
china mobile camra problem piyushgsm Infinity-Box 15 02-13-2010 06:06
china mobiles big problem multi_mobile Sony Ericsson Hardware Repair 0 10-15-2008 16:23
china mobile conectivity problem burraq Infinity-Box 1 07-17-2008 12:11
Page generated in 0.43275 seconds with 8 queries
