Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones > Chinese Phones Hardware Repair
Old 09-25-2012, 09:12   #1 (permalink)
Member: 601200
Thanks Meter: 139
China mobile in network failed to register
I have 2 china mobile shown emergency. When I search network,list show correctly but when i try to register shows failed to register. i format the phone and imei ok.
any solution pls...
Old 09-25-2012, 09:42   #2 (permalink)
Member: 1779635
Sonork: a9dc5346107d9bac95b76417
Thanks Meter: 17
try change power amp......
bossss
Old 09-25-2012, 10:22   #3 (permalink)
Super Moderator
Parash's Avatar
Member: 1435864
Sonork: Pm only
Thanks Meter: 1,675
any solution pls...
Try to change PA(network ic). Maybe your problem will be solved.
BR.
Old 09-25-2012, 12:30   #4 (permalink)
NUR_MOBILE's Avatar
Member: 1615978
Sonork: 100.1607951
Thanks Meter: 257
any solution pls...
try u network ic rehot , your not solve , give me u network ic number
i try to help u ,,
Br,
nur_mobile
Old 09-25-2012, 19:59   #5 (permalink)
Member: 1423332
If network gone on mtk 6252/53/25/35 just write cnv file as maximam value but same cnv case like also use same chip and projected ic no service emergency and serching problem done by cnv ...thanks for connecting form by dragan team
WE ARE UNSTOPBBLE...
Plz press thanks...
The Following User Says Thank You to braslet2007 For This Useful Post:
Old 10-09-2012, 07:02   #6 (permalink)
Member: 601200
Thanks Meter: 139
i try to help u ,,
br,
nur_mobile
yxtel x88
rda 6231
ua12443209
Old 10-09-2012, 19:56   #7 (permalink)
..:rubelstar:.*'s Avatar
Member: 1615212
Sonork: 100.1597410
Thanks Meter: 113
Arrow
any solution pls...
1st check pa / 75%
2nd C.P.U reball or change / 25%
Br,
..::rubelstar::..*
Old 10-09-2012, 21:03   #8 (permalink)
.:::SM PRINCE:::.'s Avatar
Member: 1188409
Sonork: 100.1616589
Thanks Meter: 250
yxtel x88
rda 6231
ua12443209
remov pa 6231
make jumper
i get sucses many time
for jumper method check here
http://forum.gsmhosting.com/vbb/f457...l-man-1325770/
Do any action by your own risk
Old 10-14-2012, 10:22   #9 (permalink)
NUR_MOBILE's Avatar
Member: 1615978
Sonork: 100.1607951
Thanks Meter: 257
yxtel x88
rda 6231
ua12443209
try u solution i am tested ,
The Following User Says Thank You to NUR_MOBILE For This Useful Post:
Old 10-14-2012, 10:37   #10 (permalink)
..::Gsmideazone::..'s Avatar
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,328
6231 pa is available now in bangladesh.
price is so low
just buy and put new 1.
it is so easy
to know about it contact with me or helpful-man
Old 10-14-2012, 10:37   #11 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 922
this is not profect solution only temprary will show signals if this method is correct but not work properly so better change with new one.
The Following 2 Users Say Thank You to >>PakFones<< For This Useful Post:
Old 10-14-2012, 11:55   #12 (permalink)
NUR_MOBILE's Avatar
Member: 1615978
Sonork: 100.1607951
Thanks Meter: 257
@ ..::Gsmideazone::..
i know RDA 6231 price is low , i working 100% ok ,
but this solution for a member ,
anyone ic is available , for this solution see ,
Br,
NUR_MOBILE
Old 10-17-2012, 09:48   #13 (permalink)
rimiaafif's Avatar
Member: 1326433
Sonork: 100.1647696
Thanks Meter: 19
network ic RDA 1118 jumper
Old 03-16-2013, 16:25   #14 (permalink)
Member: 1359325
Sonork: 470928
Thanks Meter: 9
Thumbs down china mobile network solution
Old 03-16-2013, 16:26   #15 (permalink)
Member: 1359325
Sonork: 470928
Thanks Meter: 9
china pf network - Download - 4shared
The Following User Says Thank You to laxbo For This Useful Post:
Page generated in 0.37387 seconds with 7 queries
