11-14-2014, 08:15 | #1 (permalink) |
Freak Poster Join Date: Nov 2011 Location: sylhet;bangladesh Age: 32
Member: 1691448 Status: Offline Sonork: 1619100 Thanks Meter: 40 | symphony w22 pls help me urjnt any tested solution |
11-14-2014, 08:29 | #4 (permalink) |
Junior Member Join Date: Nov 2014 Location: India
Member: 2291561 Status: Offline Thanks Meter: 1 | I Think the customer is lying.......this sort of problem cant happen by just replacing the sim card.......he must tried to do flashing rooting or must have replaced some rom files.............nevertheless just flash the stock rom using flashboot method and that should solve it |
11-17-2014, 09:40 | #7 (permalink) |
No Life Poster Join Date: Dec 2008 Location: Apple pocket Age: 32
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | if your navigation key auto change then it will hardware fault if just come factory mode it will software case. follow the way. 1.try to do hard reset 2.flash with org rom 3.remove vol switch 4.check the shorting of volume switch component(the parts of near switch) 5.full clean and hit under light 6.final check cpu |
