dear plz up lode mobile PCB |
Have zen z66 qwerty with handsfree simbol......... Anybody have solution plz help me . . . . . Thanx in advance |
help me man 1 Attachment(s) what is bname of this cpu. it is used in Karbonn K9 mobile it is not detecting by spiderman ,gpg and flash tool. here is pic of this cpu i had attached. |
need help here http://forum.gsmhosting.com/vbb/f457...oblem-1304896/ |
rehot mtk 6218 power ic problem not solve change power ic |
white cherry bl2000 123 kypad not working any solution ? |
maximus m20 all solution in one exe by helpful-man maximus m20 all solution in one exe by helpful-man http://up.top4top.net/uploads/2011/0...f10dcf9271.jpg http://up.top4top.net/uploads/2011/0...df54624671.jpg go |
dis phone http://i51.tinypic.com/o7rakn.jpg |
here your solution s212 Reove 8Leg charging contolar http://up.top4top.net/uploads/2011/0...63cc268de1.jpg jumper this daode http://www.b3c.info/wp-content/uploa...chinad.png.png |
i also recieved here a P106+.. the problem is grounded/shorted.. it powers on but it gets hot upon using for less tha a minute.. so i disassemble it and i hunt the shorted ic... the problem is i dont have a replacement.. is there any bypass solution for this.. a 10 legged small ic. http://i214.photobucket.com/albums/c...5/DSC05164.jpg this is how the legs looks. http://i214.photobucket.com/albums/c...5/DSC05165.jpg as you can see there are two legs opposite which is connected together.. its lines is to the positive of the battery terminal.. thats why even the battery terminal got burn also... thanks in advance.... |
my phone battrey not show pls help me |
M1 in phone setting in battery option main battery option not select only slave option select manually i format with gpg dragon but problem is still not solved give any solution i think hardware fault when charger connect only slave battery charge main battery not charge i am waiting thanks in advance |
