Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
11-28-2015, 18:59 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Mexico
Member: 252707 Status: Offline Thanks Meter: 18 | After Hard Reset still blocked or having errors pop-up applications. Even when performing Hard Reset via fastboot by commands and restart device is in the same situation (whether they still blocked or application errors). The bootloader was locked so I proceeded to unlock it. The phone has Android 5.0.2 it seems. After reading tutorials on how to incorporate a ROM stock by fastboot, decided to boot into bootloader mode. flash commands executed, sent a rom Stock 5.0.2 or 4.4.4 also try to degrade, restart the phone. Motorola animated logo appears, start, and Android in May on the case of KitKat also start. The strange thing is that previously installed applications or continuous Blocked appear. Decide to enter into recovery mode, try to do everything and wipe cache. The following error message: blkdiscard /dev/block/platform/msm_sdcc.1/by-name/userdata failed on partition formatting / cache So I proceeded to repair the partition using the gpt.bin file folder via fastboot 5.0.2 with the command: fastboot flash partition gpt.bin fastboot format system All good with both commands and then again load all the software via fastboot 5.0.2 (where I got the gpt.bin file) all without errors. I got the same result start blocked by pattern or code and the same applications. I tried to install recovery by fastboot (fastboot flash recovery twrp.img) and not installed. Message appears as if it had installed, but upon entering the recovery, is recovery stock. Any questions or help is appreciated Excuse my bad English. BR |
