Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Android based
Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help
Old 04-14-2017, 02:22   #16 (permalink)
Member: 2666112
Thanks Meter: 24
https://www.youtube.com/watch?v=EZG2xSikkAo
Old 04-20-2017, 13:36   #17 (permalink)
taieeb's Avatar
Member: 781262
Thanks Meter: 70
how to assign port, port not showing
Old 06-07-2017, 04:03   #18 (permalink)
Member: 1581131
Originally Posted by ElmerLc View Post
FRP Motorola 7.0 7.1 All Security
https://www.4shared.com/file/yvzRzVh...ervice212.html
1. Install "MotoService 2.1.2" GSM SERVICES TEAM
2. After installation, perform the following procedures:
The. Go to "C: \ Program Files (x86) \ Motorola \ MotoService" (default installation location)
B. Rename "Motoweb.dll" dll to Motoweb2.dll.
W Then go to "MotoService" for the first time and close.
D. Go to "C: \ ProgramData \ Motorola \ MotoService" and rename the file
"MotoServiceOptions.json" for MotoServiceOptions2.json.
Y. Then edit the MotoServiceOptions2.json file (right-click
Put it with the notebook).
F. Edit in line 13 the following name (":: offlinemode: false"), place
"Offlinemode": true, save as MotoServiceOptions.json, close and open
The program normally done this will free the side menus.
3. Turn the unit off and then on again in "FASTBOOT" mode (POWER +
VOLUME -), select "FACTORY MODE" and press Power.
computer
4. Open the "MotoService" program, go to "Options" - "Port Settings",
On the screen, the device will select the number you want to place.
Press "Assing" and "Done"
5. In the menu select "Power Test", this will be done on the device port will appear
Once again, "Tower Test" again press this option, after this a window will open and
Press "Yes"
6. Remove the appliance from the mains and turn it on again in FACTORY MODE and
The power button again connects to the computer, which
Enable USB debugging check the option and ok.
7. Open the Adb command prompt and perform the second procedure of the old devices
(G2, G3) by entering the following command.
8. adb devices
9. adb shell content insert --url content: // settings / secure --bind
First Name: s: user_setup_complete --bind value: s: 1
10. Turn the device off and on and unlock
Sincerely:
GSM SERVICES TEAM
Copyrighted by 2016 - 2017
Like this my problem also unsupported argument...how to solve
Old 06-07-2017, 04:04   #19 (permalink)
Member: 1581131
Originally Posted by maplegsm View Post
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\hp>cd..
C:\Users>cd..
C:\>cd..
C:\>adb devices
List of devices attached
TA1040AZTQ device
C:\>adb shell content insert --url content: // settings / secure --bind
usage: adb shell content [subcommand] [options]
usage: adb shell content insert --uri <URI> [--user <USER_ID>] --bind <BINDING>
[--bind <BINDING>...]
<URI> a content provider URI.
<BINDING> binds a typed value to a column and is formatted:
<COLUMN_NAME>:<TYPE>:<COLUMN_VALUE> where:
<TYPE> specifies data type such as:
b - boolean, s - string, i - integer, l - long, f - float, d - double
Note: Omit the value for passing an empty string, e.g column:s:
Example:
# Add "new_setting" secure setting with value "new_value".
adb shell content insert --uri content://settings/secure --bind name:s:new_set
ting --bind value:s:new_value
usage: adb shell content update --uri <URI> [--user <USER_ID>] [--where <WHERE>]
<WHERE> is a SQL style where clause in quotes (You have to escape single quote
s - see example below).
Example:
# Change "new_setting" secure setting to "newer_value".
adb shell content update --uri content://settings/secure --bind value:s:newer_
value --where "name='new_setting'"
usage: adb shell content delete --uri <URI> [--user <USER_ID>] --bind <BINDING>
[--bind <BINDING>...] [--where <WHERE>]
Example:
# Remove "new_setting" secure setting.
adb shell content delete --uri content://settings/secure --where "name='new_se
tting'"
usage: adb shell content query --uri <URI> [--user <USER_ID>] [--projection <PRO
JECTION>] [--where <WHERE>] [--sort <SORT_ORDER>]
<PROJECTION> is a list of colon separated column names and is formatted:
<COLUMN_NAME>[:<COLUMN_NAME>...]
<SORT_ORDER> is the order in which rows in the result should be sorted.
Example:
# Select "name" and "value" columns from secure settings where "name" is equal
to "new_setting" and sort the result by name in ascending order.
adb shell content query --uri content://settings/secure --projection name:valu
e --where "name='new_setting'" --sort "name ASC"
usage: adb shell content call --uri <URI> --method <METHOD> [--arg <ARG>]
[--extra <BINDING> ...]
<METHOD> is the name of a provider-defined method
<ARG> is an optional string argument
<BINDING> is like --bind above, typed data of the form <KEY>:{b,s,i,l,f,d}:<VA
L>
usage: adb shell content read --uri <URI> [--user <USER_ID>]
Example:
# cat default ringtone to a file, then pull to host
adb shell 'content read --uri content://settings/system/ringtone > /mnt/sdcard
/tmp.ogg' && adb pull /mnt/sdcard/tmp.ogg
[ERROR] Unsupported argument: --url
C:\>Name: s: user_setup_complete --bind value: s: 1
Powered by Searchlight © 2017 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.16524 seconds with 7 queries
