Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Android based
Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help
Old 07-02-2013, 08:22   #1 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,070
[Guide] Hard Reset - DROID Pro by MOTOROLA ( XT610 )
Performing a hard reset will remove ALL data including the Google account, system data, application data, application settings, and downloaded applications. Only perform this reset if absolutely necessary.
Note: disable Automatic restore prior to performing a hard (factory) reset when attempting to determine whether a 3rd party application is the cause of an Operating System / Application issue.
Will be shown both the way for doing this: Peferred and alternate method
Preferred method
  1. From the home screen, select the App menu.
  2. Select Settings.
    If the application icon is missing, select App menu filter (located at the top) then select All apps.
  3. Select Privacy.
  4. From the Personal data section, select Factory Data Reset.
  5. Select Reset phone.
    If presented, enter the current passcode or draw the unlock pattern.
  6. Select Erase Everything.
    Allow up to 3 minutes for the factory data reset and reboot processes to complete.
  7. Do again the same procedure of initial setting as for a new phone.
Alternate method
  1. Press and hold the Power button.
  2. Select Power off.
  3. Press and hold the R key+M key+Power button simultaneously until the Recovery screen (exclamation point with an android figure) appears.
  4. From the Recovery screen, press the volume up+down keys simultaneously.
  5. Select wipe data/factory reset.
    Utilize the Volume keys (up / down) to highlight and the Power button to select.
  6. Select Yes -- delete all user data.
    Allow the factory reset process to complete (approximately 1 minute).
  7. Select reboot system now.
  8. Do again the same procedure of initial setting as for a new phone.
Alex
The Following 2 Users Say Thank You to moulnisky For This Useful Post:
Old 08-17-2013, 16:50   #2 (permalink)
ppdavisito's Avatar
Member: 1840836
Sonork: 100.1659703
Thanks Meter: 115
Please I need some flash file for Xt-610.Thank´s
Old 12-11-2013, 17:44   #3 (permalink)
hamzamobile55's Avatar
Member: 1878900
Sonork: 100.1625007
Thanks Meter: 110
Preferred method
  2. Select Settings.
  3. Select Privacy.
Alternate method
Alex
dear bro i have motorola xt610 probelm is pattern lock
i do all setup when i press power button
select wipe data/factroy reset
nothing working
and i dont know why this line show yellow clour
E: can't open /cache/recovery/command
E: can't open /cache/recovery/command....
please i requset give me fast reply or give me firmware this model
thanks in advance
Old 01-25-2014, 10:09   #4 (permalink)
Member: 1960501
Sonork: 100.1638964
Thanks Meter: 23
how to hard reset motorola xt701
l need to hard reset my motorola xt701
Old 01-29-2014, 04:59   #5 (permalink)
Member: 2102317
Thanks Meter: 2
l need to hard reset motorola xt910 thx
Old 02-17-2014, 03:34   #6 (permalink)
Member: 2130020
Thanks Meter: 6
is there any way to hard reset by software?
Old 12-06-2014, 08:42   #7 (permalink)
srkhan's Avatar
Member: 153695
Sonork: srkhan
Thanks Meter: 733
this Hard-reset method not working with Verizone XT610
The Following User Says Thank You to srkhan For This Useful Post:
Page generated in 0.37373 seconds with 7 queries
