Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Android based
Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help
Old 07-01-2013, 22:39   #1 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,070
[Guide] Hard Reset - DROID RAZR M by MOTOROLA ( XT907 )
Performing a hard reset will remove ALL data including the Google account, system data, application data, application settings, and downloaded applications. Only perform this reset if absolutely necessary.
Pictures, Videos and Music will also be removed. It is recommended to backup this data unless willing to lose it.
Note: Personal data such as WiFi passwords, Browser bookmarks, User dictionary, a list of installed Market applications and other customized settings can be backed-up and restored by Google's servers.
Note(2): Disable automatic restore prior to performing a hard (factory) reset when attempting to determine whether a 3rd party application is the cause of an Operating System / Application issue.
Will be shown both the way for doing this: Peferred and alternate method
Preferred method
  1. From a home screen, select Apps.
  2. From the APPS tab, select Settings.
  3. From the PERSONAL section, select Privacy.
  4. From the PERSONAL DATA section, select Factory data reset.
  5. Select Reset phone.
    If presented, enter the current passcode or draw the unlock pattern.
  6. Select Erase everything.
    Allow several minutes for the factory data reset and reboot processes to complete.
  7. Do again the same procedure of initial setting as for a new phone.
Alternate method
  1. Ensure the device is powered off.
    1. To power off, press and hold the Power button.
    2. Select Power off.
    3. Select OK.
      Allow several seconds for the device to power off.
  2. Simultaneously press and hold the Power button+Volume up key until Android system recovery screen (exclamation point with an android figure) appears then release.
  3. From the Android system recovery screen, press and hold the Volume down key, press the Volume up key then release.
  4. Select wipe data/factory reset.
    Utilize the volume keys to highlight and the Power button to select.
  5. Select Yes -- delete all user data.
    Allow several seconds for the factory data reset process to complete.
  6. Select reboot system now.
    Allow several minutes for the reboot process to complete.
Alex
The Following 2 Users Say Thank You to moulnisky For This Useful Post:
Old 12-23-2014, 13:05   #2 (permalink)
Member: 1695051
Sonork: 100.1666954:3333
Thanks Meter: 21
sir this is xt926work not work xt907
(From the Android system recovery screen, press and hold the Volume down key, press the Volume up key then release.)
xt907 model work to this keyes
(From the Android system recovery screen, press and hold the Volume up key, press the power key then release.)
Old 09-22-2015, 15:48   #3 (permalink)
PAKFAN's Avatar
Member: 424731
Sonork: 100.1669530
Thanks Meter: 18
than you sirrrrr i tri
Old 11-16-2015, 18:15   #4 (permalink)
Member: 329994
Thanks Meter: 11
yes it also work on xt 907,after pressing volume down press vol+ then wait for few sec
Old 01-09-2016, 17:54   #5 (permalink)
Member: 1606165
Sonork: mobile
Thanks Meter: 7
Thanks you sir...................................
Old 01-22-2017, 04:42   #6 (permalink)
Member: 2607208
Sonork: 100.1674686
Thanks Meter: 22
press volume up and power key same time after when logo show then volume up/volume down and power key show the recovery and last the same time up and down key press 10 to 20 secend
Page generated in 0.28972 seconds with 7 queries
