Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Android based
Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help
Old 07-01-2013, 21:40   #1 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
[Guide] Hard Reset - Motorola Devour ( A555 )
Hard Reset - Motorola Devour A555
Performing a hard reset will remove ALL data including the Google account, system data, application data, application settings and downloaded applications. Only perform this reset if absolutely necessary.
Will be shown both the way for doing this: Peferred and alternate method
Note: An hard reset can also be performed via the MyMOTOBLUR website.
Note (2): When attempting to determine if a 3rd party application is the cause of an operating system / application issue on a device that does not support the autmatic restore, skip the Google Account setup during the initial setup of the device.
Preferred method
  1. From the home screen, select the applications tab (located at the bottom of the display).
  2. Select Settings.
  3. Select SD card, USB Mass Storage, & phone storage.
  4. Select Factory data reset from the Internal phone storage section.
  5. Select Reset phone.
  6. Select Erase everything.
  7. Do again the same procedure of initial setting as for a new phone.
Alternate method
  1. Press and hold the Power button.
  2. Select Power off.
  3. Slide the keyboard open.
  4. Press and hold the Space key+R key+Power button simultaneously until the Recovery screen (exclamation point inside of a triangle) appears.
  5. From the Recovery screen, press the Z+M keys.
  6. Do again the same procedure of initial setting as for a new phone.
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 09-30-2014, 09:46   #2 (permalink)
Member: 2265797
Sonork: 100.1646791
Thanks Meter: 119
Wink tahirshan mobile software
good job
plasse tel me how to update sky vega tel
skype id
tahirshan88
Old 09-30-2014, 10:00   #3 (permalink)
Member: 1027465
sir cant gti9100 markit not responding
Old 10-15-2014, 11:01   #4 (permalink)
Member: 2256883
Thanks Meter: 13
Gr8 work along with Pic.
Old 10-22-2014, 11:17   #5 (permalink)
Member: 2265797
Sonork: 100.1646791
Thanks Meter: 119
sir im wating for your replay
sir im wating for your replay.........
Old 10-22-2014, 11:42   #6 (permalink)
easir.comilla_e's Avatar
Member: 1488757
Thanks Meter: 98
thanksssssss....................job
Page generated in 0.17022 seconds with 9 queries
