[Guide] Hard Reset - Motorola RAZR ( XT910 ) need hard reset for this device for password remove. br |
Finally done by holding bouth vol+ and vol- then power to enter download mode. Select recovery then power and wipe data/factory reset. br |
turn off the phone wait for 1 minute, hold both volume keys, and hold power key for 3 seconds, get down to recovery mode by clicking volume down and when you find a android sign with with a recovery sign, again press volum up and down to gather, you will find the full menu select factory reset and delete all the user data. and here its Done. |
Motorola RAZR XT910 Factory reset using external keys Note: It is highly recommended you use the above factory reset using the settings. If you are unable to navigate through the menu to perform a factory data reset, you can follow the steps outlined below: Power up the phone by pressing the VOL UP + VOL DOWN KEY together + PWR KEY . The device will enumerate with different BOOT OPTIONS Use the VOL DOWN Key to SCROLL and VOL UP Key to SELECT Select Recovery The device will start up with Motorola logo and power up to a little Android man logo with Exclamation mark Press the VOL UP and VOL DOWN Key together at this screen The device will display BLUE Text on a Black background . Use the VOL DOWN Key to scroll DOWN and the PWR Key to SELECT the option desired . In this case , press the VOL DOWN key till the Wipe data / factory reset is selected and press the PWR key to confirm the selection . Use the VOL DOWN key again to select YES - delete all user data and press the PWR key to CONFIRM . The device will then start performing the Factory Data Reset Once the Formatting is complete , press the PWR key to confirm a REBOOT The message rebooting is displayed on the phone. The device will reboot and start the normal power up sequence . |
1.Power up the phone by pressing the VOL UP + VOL DOWN KEY together + PWR KEY . 2.The device will enumerate with different BOOT OPTIONS 3.Use the VOL DOWN Key to SCROLL and VOL UP Key to SELECT 4.Select Recovery 5.The device will start up with Motorola logo and power up to a little Android man logo with Exclamation mark 6.Press the VOL UP and VOL DOWN Key together at this screen 7.The device will display BLUE Text on a Black background . 8.Use the VOL DOWN Key to scroll DOWN and the PWR Key to SELECT the option desired . 9.In this case , press the VOL DOWN key till the Wipe data / factory reset is selected and press the PWR key to confirm the selection . 10.Use the VOL DOWN key again to select YES - delete all user data and press the PWR key to CONFIRM . 11.The device will then start performing the Factory Data Reset 12.Once the Formatting is complete , press the PWR key to confirm a REBOOT 13.The message rebooting is displayed on the phone. 14.The device will reboot and start the normal power up sequence |
Motorola-xt910-Hard-Reset Very Easy Procedure [1] Turn off completely the Motorola -xt910 [2] Press together : VOLUME DOWN + VOLUME UP, after that continue with pressing POWER button until the option appear in the LCD. [3] Choose to enter Recovery menu. To access Recovery menu press VOLUME UP + VOLUME DOWN together. ChooseFACTORY RESET using VOLUME UP or VOLUME DOWN than press POWER BUTTON to ENTER [4] Wait several minute than The MOTOROLA RAZR / RAZR MAXX will restart by itself and ready to the first time start state. Tested By Me ;) ;) Bro:- Palash Ahammad |
You should reset your device factory settings and erase all the data. These are the steps you have to follow Menu > Settings> Privacy > Factory data reset > Reset phone. |
