Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Android based
Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help
Old 11-11-2016, 19:34   #1 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
[Guide] How To Bypass Google Account Motorola Droid Turbo XT1254 New Security 2016
How to remove Google Account From Motorola Droid Turbo XT1254?
To remove google account from Motorola Droid Turbo XT1254 we need to root device first. There are so many methods are available on internet but till today no one work for me. I appreciate Motorola developers who made this phone much secure as they can.
I have tried so many methods but failed like quick shortcut application, ##4636## on dialer, tried to get developer mode from setting, tried to flash phone with RSD Lite but phone not detected and so many other that i not remember now. Only this method work for me.
How to root Motorola Droid Turbo XT1254?
To root Motorola XT1254 we need these some Android applications. To download these apps we need to access chrome browser because all other methods are disabled in latest security pach from Motorola.
How to get access to google chrome on FRP locked phone?
  • At startup screen select language and press [NEXT]
  • One “Phone Activation” Screen Press [USE WIFI]
  • Press [NEXT]
  • Connect to WiFi network
  • Press “Privacy setting”
  • Press “View Motorola Privacy Policy”
  • Scrol down and long press on any text then Search on right corner of the cell phone.
  • Clear search and type “C” you see Chrome just tape on chrome icon. No need to write full web links in address bar to download these apps just write pakfones.com and hit enter.
  • After loading PAKFONES.COM - One Step Cell phones Solutions! page.
  • Type motorola xt1254 frp or xt1254 in search @ PAKFONES.COM - One Step Cell phones Solutions!. Now you will get post link in search results this may be on top. Press post link and you will be here at this post. now click on links and press on to download apps from these links.
Android Apps To Download
SunShine for temproot
Direct link: http://www.pakfones.com/apps/sunshine.apk
Official link: http://theroot.ninja/apks/SunShine-latest.apk
Kongo Root for root Motorola Droid Turbo this also work as temproot.
Direct link: http://www.pakfones.com/apps/KingoRoot.apk
Official link: http://d.kingoapp.com/default/KingoRoot.apk
Kingroot for permanent root Motorola Droid Turbo.
Direct link: http://www.pakfones.com/apps/Kingroot_global.apk
Official link: Kingroot_global.apk
Android Terminal to enter commands
Direct link: http://www.pakfones.com/apps/terminal.apk
Astro File Manager if you have already downloaded above Android apps and want to use OTG.
Astro File Manager: http://www.pakfones.com/apps/astro_file_manager.apk
After downloading these apps please follow the instruction below.
  • In Motorola Privacy Policy Search “Where you already typed letter “C” and got access to Chrome browser” write letter “D” you will get downloads folder.
  • Now install Astro_File_Manager.apk if you want to use already downloaded apps and continue from usb storage. This step not necessary if you have not OTG cable and USB Flash Drive.
  • Now install SunShine.apk and follow the instructions on screen. This will do temporary root.
  • Now install Kingoroot.apk and follow the screen message this will give you failed messages but don’t worry you should try atleast 3 -> 5 times it still giving failed message but you should continue to next step.
  • Now install Kingroot_global.apk and follow the instructions on screen. Please note your phone may restart during root process. Kingroot may also give failed message but you should retry. I got “Root Successfully” message in second try.
Congratulation! You have rooted you Motorola Droid Turbo. Now continue next step to remove FRP. To remove frp from motorola xt1254 we need Android Terminal application to enter bypass setup process.
Motorola Droid Turbo FRP remove commands and Terminal application.
  • Install Terminal.apk and open it.
  • Type “su” in terminal and hit Enter on keyboard grant permission to super user.
  • Then type second command correctly ”
  • content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1
  • ” and hit Enter.
The second command will bypass activation process and activate phone to normal. now you can add you account and can reset Motorola droid turbo from setting.
For more detail and video guide please visit https://goo.gl/e48VBH
Please reply in this post or on my blog if you get any problem during all process.
Br,
Old 11-28-2016, 01:37   #2 (permalink)
Member: 1024853
Thanks Meter: 24
This Video For Droid Turbo XT1254 android 5.1 build number SU4TL-49 security
2016-04-01 10000% i Done Daily 1 or 2 Cellphone Remove FRP Via This Method.
https://www.youtube.com/watch?v=2QzSPpufKzM&t=16s
Files Links Under Video Description.
Just See Single Video and All Files in 1 RAR File
Old 01-26-2017, 15:54   #3 (permalink)
Member: 1608526
Sonork: 100.1611913
Thanks Meter: 60
tested is working 1000000% by me
Old 02-01-2017, 20:45   #4 (permalink)
khanzada606's Avatar
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
6.0.1 cant be rooted so far
but bypasss done , ID is still on
Old 03-16-2017, 13:29   #5 (permalink)
papoo's Avatar
Member: 188374
Sonork: 1000.2
Thanks Meter: 203
video deleted
Bro Check Link Video Deleted Upload Another Link.
Page generated in 0.19213 seconds with 8 queries
