How to root Motorola RAZR D3 These are the instructions to root Motorola RAZR D3 smartphone using Framaroot Application on Phone itself (no need of computer to root). Requirements: Your Motorola RAZR D3 smartphone should have atleast 10-20 percent of phone battery to perform the rooting process. Root Motorola RAZR D3 smartphone with Framaroot Step 1: Enable installation of 3 party Apps on your Motorola RAZR D3 smartphone . To Enable, Open Settings > Security > Device Administration >Unknown Sources (tick to enable it). http://www.moulnisky.com/rooting/Ins...own-source.png Step 2: Download and install Framaroot Application on your Motorola RAZR D3 smartphone. Once installation is completed you will be able to see the Framaroot Icon in the App Menu. http://www.moulnisky.com/rooting/Fra...d-on-Stock.png Step 3: Now, Tap on the Framaroot App Icon to Open it. http://www.moulnisky.com/rooting/Ope...t-on-Stock.png Step 4: Once Framaroot Application is launched you will be able to see the following screen on your Device: http://www.moulnisky.com/rooting/Framaroot-Boromir.png Step 5: In Framaroot, You will be able to see 3 options i.e Boromir and Faramir, Barahir. Tap on the Barahir Option. http://www.moulnisky.com/rooting/Fra...ct-Boromir.png Step 6: Now, you will be able to see the Framaroot success Message on the Phone Screen. http://www.moulnisky.com/rooting/fra...ss-barahir.png Step 7: Now, you have to restart your Device. Now your Motorola RAZR D3 smartphone is Rooted. To check whether your phone is rooted correctly, open Applications Menu, there you will be able to see a new app installed, called SuperSU. If this app exist then it means you have successfully rooted your device. http://www.moulnisky.com/rooting/Fra...lled-Stock.png Optional: You can also verify that your device is successfully rooted or not by Root Checker Application. Keep in Mind:BR Alex |
In which any other application for root? |
droid razr Quote:
how to roont this device? motorola droid razr |
any other applications to root xplay? |
hi i have problum to login merapi tool my device id is 876-243-714 and tell me how to re register device |
root with kingo root off on super su removed from mobile... |
Motorola mobile xt1080 remove supersu when rooing with kingo root frome pc |
guys, any help with my xt1080 verizon rooting? i have tried 4 different softwares and its not rooting, any help?? |
If moto g4plus 8.0 version update conform hi moto g4plus oreo update conform |
