Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
05-15-2017, 21:08 | #1 (permalink) |
Junior Member Join Date: Jun 2011 Location: NARASARAOPET Age: 31
Member: 1599678 Status: Offline Thanks Meter: 0 | I need motog1 xt1033 original flash file SOFT* BRICK. STOUCK*ON*MOTO*LOGO*(BOOTLOOP)* i*alread*try*to*flash*the*maney*flash*files*like*f olcon*retail*asia,untouched* retail*asio.......like*flash*fileS* I*ALSO*TRY*TO*DOWNGRADE*THE*BOOT*LODER* BUT*IT*NOT*SUCESS** my*bootloder*has*unlocked, AP*FAST*BOOT* 41.1A*(SHA*80481ae,*2015*04*10*14:30:28)* STATUS*CODE*UNLOCKED*3* finally*i*try*to*flash*with falcon_retbr_ds-user 5.1 LPBS23.13-56-2 2 release-keysMSM8626BP_1032.3116.98.00R MBM Version: 41.1A Modem Version: MSM8626BP_1032. IT SHOWS COMMAND ERROR HAB CHECKED FOR BOOT PLEAS ANY BODY PROVIDE OG FILE OF MY MOBILE |
05-16-2017, 10:06 | #2 (permalink) |
No Life Poster Join Date: Jul 2001 Age: 42
Member: 5184 Status: Offline Thanks Meter: 246 | Check some tutorial below: Download and install Motorola Correct Drivers. 1. Download 5.0.2 firmware from here: https://drive.google.com/file/d/0B5u...F3MlhaUjQ/edit and Extract it to a folder (More Links and mirrors in Downloads section at the end of the post) 2. Download mfastboot-v2 from link here: https://www.androidfilehost.com/?fid=24533100289589561 and Extract it into the same folder 3. Reboot the phone into Bootloader 4. Step 4 can be done two ways Method 1 is manually typing commands and teaches you how a bit about android Method 2 is more automatic and easier Method 1:Run Following commands from the Command Prompt after cd-ing to the folder, one by one If you do not wish to lock bootloader skip 4.1 and 4.3 4.1 mfastboot.exe oem lock begin ----------------------- 4.2 mfastboot.exe flash partition gpt.bin mfastboot.exe flash motoboot motoboot.img mfastboot.exe flash logo logo.bin mfastboot.exe flash boot boot.img mfastboot.exe flash recovery recovery.img mfastboot.exe flash system system.img_sparsechunk.0 mfastboot.exe flash system system.img_sparsechunk.1 mfastboot.exe flash system system.img_sparsechunk.2 mfastboot.exe flash system system.img_sparsechunk.3 mfastboot.exe flash modem NON-HLOS.bin mfastboot.exe erase modemst1 mfastboot.exe erase modemst2 mfastboot.exe flash fsg fsg.mbn mfastboot.exe erase cache mfastboot.exe erase userdata ------------- 4.3 mfastboot.exe oem lock ------------- 4.4 mfastboot.exe reboot --------------- Or Method 2: Download Retail_AS.bat/Retail_AS+LockBootLoader.bat from Attachments, Extract it to the same folder and just run 5. And there you go! Phone is booting Lollipop Downloads 5.0.2: No Dev-Host link because of their limit of 512 MB 1.GDrive : https://drive.google.com/file/d/0B5u...F3MlhaUjQ/edit 2.Mega : https://mega.nz/#!y1EQWQxa!y1zJPchfA...roX06LLwF_ZsLo Check and try . Regards |
