Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
08-03-2016, 16:43 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: chandausi
Member: 652183 Status: Offline Thanks Meter: 48 | moto e xt1022 hang on logo after flash |
08-04-2016, 10:38 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | First all unlock your bootloader: https://motorola-global-portal.custh...-your-device-a How to Install Stock Firmware On Moto xt1022. Download and install Moto USB Drivers b). Enable USB debugging on your phone (Go to Settings -> Developer options and enable USB Debugging). c). Download firmware for Moto xt1022 and unzip the file to a folder xml.zip. https://androidfilehost.com/?w=files...e&sort_dir=ASC d). ADB and Fastboot Download mfastboot-v2.zip minimal tool, unzip the content and move ITS files to the firmware files folder. 1. Turn off your phone and then a to press and hold the Volume Down + Power buttons Simultaneously for a few seconds. This will boot the phone into bootloader mode. USB 2. Now, connect your Moto X to your PC via cable go to the folder Where the firmware is located and launch a command window from there (Press Shift key, right click and select 'Open command window here') 3. Now, issue all the commands provided below one by one. mfastboot oem fb_mode_set mfastboot flash partition gpt.bin mfastboot flash bootloader bootloader.img mfastboot flash logo logo.bin mfastboot flash boot boot.img mfastboot flash recovery recovery.img mfastboot flash system system.img_sparsechunk.0 mfastboot flash system system.img_sparsechunk.1 mfastboot flash system system.img_sparsechunk.2 mfastboot flash system system.img_sparsechunk.3 mfastboot flash system system.img_sparsechunk.4 mfastboot flash system system.img_sparsechunk.5 NON-flash modem mfastboot HLOS.bin mfastboot erase modemst1 mfastboot erase modemst2 mfastboot flash fsg fsg.mbn mfastboot erase cache mfastboot erase userdata mfastboot erase customize mfastboot oem carrier config vzw mfastboot oem fb_mode_clear mfastboot reboot |
04-27-2017, 07:15 | #3 (permalink) |
Crazy Poster Join Date: May 2013 Location: INDIAN
Member: 1943146 Status: Offline Thanks Meter: 11 | moto e flash set ok Port : Fastboot Interface Baud Rate : Not Applicable Device : Motorola QC Operation : Flash Fw Model : condor_retla_ds Fw Version : condor_retla_ds-user 5.1 LPCS23.13-34.8-3 3 release-keysMSM8610BP_18033.4614.45.00R Searching for Device in FastBoot Mode... OK Reading Phone Information... Model : XT1022 Boot Ver. : 500E Baseband : Not Found Software : Blur_Version.23.26.8.condor_retaildsds.retaildsdsa ll.en.03 IMEI : 359299056230514 CPU : MSM8210 CS RAM : 1024MB Hynix S4 SDRAM DIE=4Gb EMMC : 4GB Hynix REV=06 PRV=05 TYPE=17 Sending Data [partition]... Done Sending Data [motoboot]... Done Sending Data [logo]... Done Sending Data [boot]... Done Sending Data [recovery]... Done Sending Data [system]... Done Sending Data [system]... Done Sending Data [system]... Done Sending Data [system]... Done Sending Data [modem]... Done Erasing [modemst1]... Done Erasing [modemst2]... Done Sending Data [fsg]... Done Erasing [cache]... Done Erasing [userdata]... Done Operation Finished. Elapsed Time: 02:39 [Module Ver. 3.8] Log Saved to Logs\170427_113528.log |
