Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
03-02-2017, 15:13 | #46 (permalink) | |
Freak Poster Join Date: Oct 2016 Location: INDIA,ORISSA,BHADRAK Age: 33
Member: 2633575 Status: Offline Sonork: 100.1675503:binod_orissa Thanks Meter: 22 | don't use m Quote:
don't use m use fastboot...... | |
03-16-2017, 19:22 | #47 (permalink) |
No Life Poster Join Date: Sep 2012 Location: Tiptur- Karnataka, india
Member: 1809212 Status: Offline Sonork: 1000.2 Thanks Meter: 79 | Need Xt-1022 Flash file For This Ver. (bootloader) ro.build.version.full[0]: Blur_Version.21.12.40.condor_reta (bootloader) ro.build.version.full[1]: ildsds.retaildsdsall.en.03 ro.build.version.full: Done finished. total time: 0.054s |
03-26-2017, 09:51 | #49 (permalink) | |
No Life Poster Join Date: Jul 2010 Location: chennai, india
Member: 1354113 Status: Offline Thanks Meter: 669 | Quote:
press only thank button | |
04-05-2017, 15:37 | #51 (permalink) |
Junior Member Join Date: Jul 2016
Member: 2603322 Status: Offline Thanks Meter: 0 | hi friends i need moto xt1079 firmware (v6.0/MPBS24.65-34-5/0:USER/RELESE-KEY) PROBULAM OF MOBILE FASTBOTE ONLY DEVICE LOCK PLS HELP ME BRO.... I TRY TO THIS VERSION BUT NOT READY thea_retasia_ds-user 6.0 MPB24.65-34 29 release-keys |
05-09-2017, 05:43 | #53 (permalink) |
Junior Member Join Date: Jun 2016 Location: Erode
Member: 2587311 Status: Offline Thanks Meter: 0 | Hi everyone, I have faced the automatically run in fastboot mode in my moto e so as per your instruction we had done the flash & the complaint has solved. But after 2 months the mobile has same problem. so i had done once again the flashing & found mobile ok. Then after yesterday the mobile has same problem. so kindly give the permanent solution for my mobile. |
06-11-2017, 17:00 | #54 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2614987 Status: Offline Thanks Meter: 5 | moto xt1022 tested files here https://firmware.center/firmware/Mot.../Stock/XT1022/ you can check getvar info in moto fastboot flash at 8 no. option or try http://forum.gsmhosting.com/vbb/f783...mware-2028182/ flash with same version 100% done |
07-21-2017, 06:45 | #55 (permalink) |
Junior Member Join Date: Nov 2006 Location: lockhnow Age: 44
Member: 396979 Status: Offline Thanks Meter: 0 | I:\New folder\moto flash\xt1022\Mfastboot>mfastboot flash partition gpt.bin 'mfastboot' is not recognized as an internal or external command, operable program or batch file. I:\New folder\moto flash\xt1022\Mfastboot> how solve this erorr sir |
08-30-2017, 14:31 | #57 (permalink) |
Freak Poster Join Date: Sep 2007 Location: India
Member: 579916 Status: Offline Thanks Meter: 10 | Qualcomm HS-USB QDLoader 9008 moto 1022 flashed phone after that phne started all ok after restart went to this Qualcomm HS-USB QDLoader 9008 after usb connect to computer plzzzz help guys |
09-01-2017, 13:36 | #58 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2685137 Status: Offline Thanks Meter: 0 | Do Not Use Commands if you are not aware of it when to command what using minimal adb fastboot or other mfastboot.. Download the Motorola Mobility Driver before flashing, verify the current firmware installed in the phone in recovery mode you can check it there which software is required to be downloaded.. Then use RSD Lite flasher for installing |
