Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
10-30-2016, 05:25 | #16 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Pakistan/UAE/WorldWide Age: 26
Member: 2302076 Status: Offline Sonork: 100.1663298 Thanks Meter: 185 | *#*#4636#*#* code not working Google Chrome not opening Any solution for xt1528?? Sent from my Fire Phone using Tapatalk |
11-12-2016, 14:37 | #17 (permalink) |
Junior Member Join Date: Nov 2016
Member: 2648211 Status: Offline Thanks Meter: 0 | Hallo....bypass frp lock for moto e2 xt 1521 moto g3 moto g moto x and other e2 g3 g models Start phone Click on yellow button Then you see wifi settings Click add networks There type any thing and long press on that text Then you can see share button Click on it,it will show some apps click on hangout Open hang out and select any previous msg or you can create a msg with any mobile number Click on that msg On the top menu there is three dots click on it There select people option There select on the number displayed on phone It will help to go keypad Here type *#*#4636#*#* It will open a menu there select user**** Then click back button on top of the screen Done you are on the settings menu there you can select user option and add user...but you can't use full setting....you will be a second user.... For use full settings go to YouTube/data usage/Google privacy policy/chrome/download aptoid,Nova launcher,test dpc,multiwindow app/open multiwindow app Select Nova launcher Then you will be in home screen select test dpc Open and select 2nd option press encrypt Your phone need 75% charge to encrpt After encrpt phone will automatically turn on Click on yellow button and wait Then you will see setup option select it and select for owner On side you can see option for multiwindow there select Nova launcher Go setting click factory reset Done...!! You bypassed your phone... Sry for bad english....😬😬😬😬 |
01-09-2017, 20:33 | #20 (permalink) |
No Life Poster Join Date: Jul 2007 Location: My Computer
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | Motorola Google Account Bypass Android 6.0.1 (Android Security Patch Level 1 September 2016) This method work on all Motorola devices running patch level 1 September 2016 or lower. |
01-09-2017, 23:21 | #21 (permalink) |
Member: 2302076 Status: Offline Sonork: 100.1663298 Thanks Meter: 185 | @>>PakFones<< Nfc not work in moto e2 And this method was also not work You can't make any profile in test dpc because test dpc unfortunately stopped I test it before but this method doesn't work Br, Shahzaib Jahangir |
The Following 2 Users Say Thank You to shahsoft For This Useful Post: |
01-17-2017, 09:32 | #23 (permalink) |
No Life Poster Join Date: Jul 2006 Location: TAMILNADU...HOSUR
Member: 308822 Status: Offline Thanks Meter: 380 | 1. Boot into bootloader (hold vol down and power button while off) and connect to PC via USB. 2. Use vol down to scroll to 'QCOM' and select with vol up. 3. After phone reboots, wait for adb prompt on phone screen and select OK. 4. Open adb command prompt and enter |
The Following User Says Thank You to gs cell For This Useful Post: |
01-18-2017, 06:52 | #24 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Gujrat (India) Age: 38
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | Quote:
what command for frp reset, | |
09-23-2017, 15:08 | #25 (permalink) |
Freak Poster Join Date: Apr 2010 Location: Gautam Buddha Nagar Age: 35
Member: 1291309 Status: Offline Sonork: [email protected] Thanks Meter: 58 | moto E2 xt 1521 esy frp removed 1000% 1. Boot into bootloader (hold vol down and power button while off) and connect to PC via USB. 2. Use vol down to scroll to 'QCOM' and select with vol up. 3. After phone reboots, wait for adb prompt on phone screen and select OK. 4. Open adb command prompt and enter |
