Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Android based
Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help
Old 07-01-2015, 13:42   #1 (permalink)
Member: 422649
Sonork: não
Thanks Meter: 27
Unhappy Moto x XT1058 erros...Need help
Moto x XT1058 Version: 4.4.4. Errors that appear on the screen: "The initiator stopped" "the processo.com.google.gapps stopped"
My moto x not catch firmware is giving me this error help some solution even sigima box staff can see this type of defect and help in the future.
This problem is a memory error, I've tried in many ways more so far decided no. The memory of the device corrupts or is packed with files and makes recording a new firmware or hardware impossible, you record the more firmware has no effect, we have some forum threads talking about, however, none solution to date.
Old 07-01-2015, 13:54   #2 (permalink)
Member: 1837438
Sonork: unknown
Thanks Meter: 659
Originally Posted by ivan33 View Post
Jamesjerss: I need your help urgently please ...
This Is Software Problem ,due to Gapp pakage,pls update/flash your handset
Old 07-01-2015, 14:15   #3 (permalink)
Member: 422649
Sonork: não
Thanks Meter: 27
Thumbs down Moto x blunders ..
It has been done several flash with several firmware versions .. And resolve is not the same version 4.4.4 .. giving these errors on the screen
Old 07-01-2015, 23:11   #4 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Try this file
RETAIL-XT1058_BR_5.1-222.21.7-BR.zip
After flash wipe cache nd userdata (bootloader must b unlocked )
mfastboot erase cache
mfastboot erase userdata
Old 07-01-2015, 23:11   #5 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Try this file
Old 07-02-2015, 13:55   #6 (permalink)
Member: 422649
Sonork: não
Thanks Meter: 27
Thumbs down MotoX unresolved with this firmware
I have been through this flash and he was the same thing not solved anything ... there's no way to delete it and replace it back ... I've been several firmware ..
Help me please ..
Old 07-04-2015, 09:15   #7 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
You try cm 12 based rom or Asop roms but dnt flash ful gapps only flash minimal gapps nd check .
Sent from my Moto G 2014 using Tapatalk
Old 07-05-2015, 14:44   #8 (permalink)
Member: 422649
Sonork: não
Thanks Meter: 27
Red face Help urgent moto x 1058 ...
jamesjerss:
I would like you have placed the flash files for me to play on the device?
I put a tutorial here for me to do if possible ..
Thank you very much ..
Old 07-05-2015, 15:33   #9 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Note: Also this could be a hardware issue.
Twrp recovery Here
Gapps
Rom here
Unlock yur bootloader nd flash the twrp recovery via fastboot
Boot in Twrp recovery
Full backup up yur current rom
Wipe data ,cache,delvik,cache,system
Flash rom den gapps
reboot
Old 07-07-2015, 13:22   #10 (permalink)
Member: 422649
Sonork: não
Thanks Meter: 27
Red face jamesjerss
jamesjerss
u have some video, tutorial because I do not entendir right to be a little confusing for me to understand the procedure that your tutorial ..
Tutorial how should I do ???
Old 07-07-2015, 13:57   #11 (permalink)
Member: 1837438
Sonork: unknown
Thanks Meter: 659
jamesjerss
what is confuse here....
1st: Unlock Your Boot Loader
2nd: Download TWRP Custom Recovery From Here
3rd:Flash The Downloaded TWRP Custom Recovery Via Fastboot.
(Fastboot Mode:Reboot Your Handset Into Fastboot Mode By Pressing power button and volume down key at the same time,
Keep pressing these buttons for about 6, or 7 seconds,Release the keys when the fastboot / bootloader mode is being displayed)
Fastboot Recovery Flashing EG:-
fastboot flash recovery twrp-2.8.7.0-ghost.img
4th:Back Up Your Current Rom Via Custom Recovery Option "BACK UP"
5th:Wipe Under "Wipe ";Wipe Data ,Cache,Delvik,Cache&System
6thownload Custom Rom From Here&Download Gapps From Here
7th:Put Your Custom Rom & Gapps To Internal Memory via MTP.
8th:Install Custom Rom,Then Gapps
9th:Reboot
Br,
Habeeb Kambrath
Old 07-08-2015, 12:34   #12 (permalink)
Member: 422649
Sonork: não
Thanks Meter: 27
Thumbs up Agredecimento.. jamesjerss ,habeebkambrath.....
My sincere agredecimentos you that helped me .. Unfortuantely had to estregar the Moto X customer .. To my thanks for the strength and attention .....
The Following User Says Thank You to ivan33 For This Useful Post:
Old 12-22-2015, 12:20   #13 (permalink)
sunshine4u's Avatar
Member: 1383464
Sonork: 100.1669490
Thanks Meter: 100
i have MOTO X XT1058 from AT&T after update on 5.1 phone has no option for back camera whats the solution i have to reflash the AT&T rom again or downgrade it to 4.4??
JAMES please share the AT&T rom link or any other way to bring back camera option back i already clear cache of the camera app reset device many time but no luck
Page generated in 0.22942 seconds with 9 queries
