Moto X4 XT1900-2 No bootable A/B slot Failed to boot linux Moto X4 XT1900-2 No bootable A/B slot Failed to boot linux, falling Back to fastboot fastboot reason: Fall Through from normal boot mode i have flashed this phone with these 2 files Successfully but after flashing it reboots automatically 4-5 times then returns to this bootloader screen. help me out Developers Team Scrrenshots are here https://drive.google.com/open?id=1MY...uTWpr7esQbCzYW |
same problem here with X1941-4 Moto One Tried to downgrade, failed to write boot, after 1 time was flashed & booted. Now A/B slot error. Lenovo Moto Smart Assistant's rescue function fail: This device is not supported. Bootloader is locked. Any idea? |
just post getvar info of your device i'll help you solve it out. |
happy to hear that sagarjais :) didnt have time to play more with this, just updated fastboot.exe Code: fastboot getvar all INFOslot-count: 2 INFOslot-successful:_a: No INFOslot-successful:_b: No INFOslot-bootable:_a: No INFOslot-bootable:_b: Yes INFOslot-retry-count:_a: 0 INFOslot-retry-count:_b: 6 |
Here is your firmware flash all the files seperately using fastboot commands one by one DEEN_RETAIL_9.0_PPKS29.68-16-36-7_cid50_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml.zip Best Regards Sagar Jaiswal Press Thanks If Helped |
still not booting, even flashing one by one which version of fastboot you are using? |
and fb commands are below fastboot oem fb_mode_set fastboot flash partition gpt.bin fastboot flash bootloader bootloader.img fastboot flash logo logo.bin fastboot flash boot boot.img fastboot flash recovery recovery.img fastboot flash dsp adspso.bin fastboot flash oem oem.img fastboot flash system system.img_sparsechunk.0 fastboot flash system system.img_sparsechunk.1 fastboot flash system system.img_sparsechunk.2 fastboot flash system system.img_sparsechunk.3 fastboot flash system system.img_sparsechunk.4 fastboot flash system system.img_sparsechunk.5 fastboot flash system system.img_sparsechunk.6 fastboot flash system system.img_sparsechunk.7 fastboot flash system system.img_sparsechunk.8 fastboot flash modem NON-HLOS.bin fastboot erase modemst1 fastboot erase modemst2 fastboot flash fsg fsg.mbn fastboot erase cache fastboot erase userdata fastboot erase customize fastboot erase clogo fastboot oem fb_mode_clear fastboot reboot |
use this tool works perfect |
try flashing this firmware: https://mirrors.lolinet.com/firmware...LT_CFC.xml.zip |
so kindly check the info before posting Best Regards Sagar Jaiswal Press Thanks If Helped |
Code: INFOro.carrier: reteu |
INFOro.build.version.full[0]: Blur_Version.39.401.27.deen.retai INFOro.build.version.full[1]: l.en.US |
hello guys, no difference between RETAIL or RETEU flashing, both accepted by phone Found something strange, after flashing but before reboot, getvar all shows: flashing DEEN_RETAIL_9.0_PPKS29.68-16-36-7.... (bootloader) slot-bootable:_a: Yes (bootloader) slot-bootable:_b: Yes (bootloader) slot-retry-count:_a: 7 (bootloader) slot-retry-count:_b: 0 fastboot reboot getvar all (bootloader) slot-bootable:_a: No (bootloader) slot-bootable:_b: No so far not found the solution, anyone can repair remotely please send PM |
no a/b slot Quote:
:\Program Files (x86)\Minimal ADB and Fastboot>fastboot getvar all (bootloader) version: 0.5 (bootloader) version-bootloader: MBM-2.1-deen_retail-6f8d34a-190128 (bootloader) product: deen (bootloader) board: deen (bootloader) secure: yes (bootloader) hwrev: PVT1 (bootloader) radio: 2 (bootloader) storage-type: emmc (bootloader) emmc: 64GB SAMSUNG RH64AB RV=08 PV=05 FV=0000000000000005 (bootloader) ram: 4GB SAMSUNG LP3 DIE=8Gb M5=01 M6=06 M7=00 M8=5F (bootloader) cpu: MSM8953 (bootloader) serialno: ZL5228FXC9 (bootloader) cid: 0x0032 (bootloader) channelid: 0x29 (bootloader) uid: AE64A4A600000000000000000000 (bootloader) securestate: oem_locked (bootloader) iswarrantyvoid: no (bootloader) max-download-size: 534773760 (bootloader) reason: Fall-through from normal boot mode (bootloader) imei: 3555460907 (bootloader) meid: (bootloader) date: 09-18-2018 (bootloader) sku: XT1941-5 (bootloader) carrier_sku: XT1941-5 (bootloader) battid: SB18C30734 (bootloader) iccid: (bootloader) cust_md5: (bootloader) max-sparse-size: 268435456 (bootloader) current-time: "Sun Dec 16 17: 4:59 UTC 2018" (bootloader) ro.build.fingerprint[0]: motorola/deen/deen_sprout:9/PPKS29 (bootloader) ro.build.fingerprint[1]: .68-16-21-2/99791:user/release-key (bootloader) ro.build.fingerprint[2]: s (bootloader) poweroffalarm: 0 (bootloader) ro.build.version.full[0]: Blur_Version.39.221.3.deen.retail (bootloader) ro.build.version.full[1]: .en.US (bootloader) ro.build.version.qcom: LA.UM.7.6.r1-02500-89xx.0 (bootloader) version-baseband: M8953_16.15.02.19R DEEN_LATAM_CUST (bootloader) kernel.version[0]: Linux version 3.18.115-perf-g9f9181a (hu (bootloader) kernel.version[1]: dsoncm@ilclbld67) (gcc version 4.9.x 201 (bootloader) kernel.version[2]: 50123 (prerelease) (GCC) ) #1 SMP PREEMP (bootloader) kernel.version[3]: T Thu Dec 27 09:26:21 CST 2018 (bootloader) sbl1.git: sbl1.git (bootloader) rpm.git: rpm.git (bootloader) tz.git: tz.git (bootloader) devcfg.git: devcfg.git (bootloader) keymaster.git: keymaster.git (bootloader) cmnlib.git: cmnlib.git (bootloader) cmnlib64.git: cmnlib64.git (bootloader) prov.git: prov.git (bootloader) aboot.git: MBM-2.1-deen_retail-6f8d34a-190128 (bootloader) frp-state: protected (77) (bootloader) ro.carrier: openmx (bootloader) current-slot: (bootloader) running-boot-lun: 0 (bootloader) running-slot: (bootloader) slot-suffixes: _a,_b (bootloader) slot-count: 2 (bootloader) slot-successful:_a: No (bootloader) slot-successful:_b: No (bootloader) slot-bootable:_a: No (bootloader) slot-bootable:_b: No (bootloader) slot-retry-count:_a: 0 (bootloader) slot-retry-count:_b: 0 all: listed above finished. total time: 0.445s |
