Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
09-26-2019, 14:30 | #1 (permalink) |
Freak Poster Join Date: Mar 2015 Location: New Delhi Age: 28
Member: 2355125 Status: Offline Thanks Meter: 52 | Moto X4 XT1900-2 No bootable A/B slot Failed to boot linux fastboot reason: Fall Through from normal boot mode i have flashed this phone with these 2 files Successfully but after flashing it reboots automatically 4-5 times then returns to this bootloader screen. help me out Developers Team Scrrenshots are here https://drive.google.com/open?id=1MY...uTWpr7esQbCzYW |
10-09-2019, 10:31 | #2 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Hungary Age: 40
Member: 22869 Status: Offline Thanks Meter: 132 | same problem here with X1941-4 Moto One Tried to downgrade, failed to write boot, after 1 time was flashed & booted. Now A/B slot error. Lenovo Moto Smart Assistant's rescue function fail: This device is not supported. Bootloader is locked. Any idea? |
10-09-2019, 13:00 | #3 (permalink) | |
Member: 2355125 Status: Offline Thanks Meter: 52 | Quote:
just post getvar info of your device i'll help you solve it out. | |
10-09-2019, 14:49 | #4 (permalink) |
Member: 22869 Status: Offline Thanks Meter: 132 | happy to hear that sagarjais didnt have time to play more with this, just updated fastboot.exe Code: fastboot getvar all INFOversion: 0.5 INFOversion-bootloader: MBM-2.1-deen_retail-2ddc041-190826 INFOproduct: deen INFOboard: deen INFOsecure: yes INFOhwrev: PVT1 INFOradio: 7 INFOstorage-type: emmc INFOemmc: 64GB SAMSUNG RH64AB RV=08 PV=05 FV=0000000000000005 INFOram: 4GB SAMSUNG LP3 DIE=8Gb M5=01 M6=06 M7=00 M8=5F INFOcpu: MSM8953 INFOserialno: ZL5229xxxx INFOcid: 0x0032 INFOchannelid: 0x00 INFOuid: 3CFE31E700000000000000000000 INFOsecurestate: oem_locked INFOiswarrantyvoid: no INFOmax-download-size: 534773760 INFOreason: Volume down key pressed INFOimei: 359548091xxxxxx INFOmeid: INFOdate: 10-25-2018 INFOsku: XT1941-4 INFOcarrier_sku: XT1941-4 INFObattid: SB18C30734 INFOiccid: INFOcust_md5: INFOmax-sparse-size: 268435456 INFOcurrent-time: "Tue Aug 20 9:17:29 UTC 2019" INFOro.build.fingerprint[0]: motorola/deen/deen_sprout:9/PPKS29 INFOro.build.fingerprint[1]: .68-16-36-7/8c3bf:user/release-key INFOro.build.fingerprint[2]: s INFOpoweroffalarm: 0 INFOro.build.version.full[0]: Blur_Version.39.401.27.deen.retai INFOro.build.version.full[1]: l.en.US INFOro.build.version.qcom: LA.UM.7.6.r1-02500-89xx.0 INFOversion-baseband: M8953_16.15.02.23R DEEN_APACDSDS_CUST INFOkernel.version[0]: Linux version 3.18.115-perf-ge7150b7-041 INFOkernel.version[1]: 57-gc8b6600 (hudsoncm@ilclbld66) (gcc ve INFOkernel.version[2]: rsion 4.9.x 20150123 (prerelease) (GCC) INFOkernel.version[3]: ) #1 SMP PREEMPT Mon Aug 26 21:16:22 CDT INFOkernel.version[4]: 2019 INFOsbl1.git: MBM-2.1-deen_retail-b314434-190826 INFOrpm.git: MBM-2.1-deen_retail-80327a1-190826 INFOtz.git: MBM-2.1-deen_retail-a495796-dirty-190826 INFOdevcfg.git: MBM-2.1-deen_retail-a495796-dirty-190826 INFOkeymaster.git: MBM-2.1-deen_retail-a495796-190826 INFOcmnlib.git: MBM-2.1-deen_retail-a495796-190826 INFOcmnlib64.git: MBM-2.1-deen_retail-a495796-190826 INFOprov.git: MBM-2.1-deen_retail-a495796-dirty-190826 INFOaboot.git: MBM-2.1-deen_retail-2ddc041-190826 INFOfrp-state: protected (77) INFOro.carrier: reteu INFOcurrent-slot: _b INFOrunning-boot-lun: 0 INFOrunning-slot: _b INFOslot-suffixes: _a,_b INFOslot-count: 2 INFOslot-successful:_a: No INFOslot-successful:_b: No INFOslot-bootable:_a: No INFOslot-bootable:_b: Yes INFOslot-retry-count:_a: 0 INFOslot-retry-count:_b: 6 all: listed above finished. total time: 0.044s INFOslot-count: 2 INFOslot-successful:_a: No INFOslot-successful:_b: No INFOslot-bootable:_a: No INFOslot-bootable:_b: Yes INFOslot-retry-count:_a: 0 INFOslot-retry-count:_b: 6 |
10-09-2019, 15:26 | #5 (permalink) | |
Here is your firmware flash all the files seperately using fastboot commands one by one DEEN_RETAIL_9.0_PPKS29.68-16-36-7_cid50_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml.zip Best Regards Sagar Jaiswal Press Thanks If Helped | |
10-10-2019, 08:02 | #6 (permalink) |
Member: 22869 Status: Offline Thanks Meter: 132 | still not booting, even flashing one by one which version of fastboot you are using? |
The Following User Says Thank You to fofesz For This Useful Post: |
10-10-2019, 12:35 | #7 (permalink) | |
and fb commands are below fastboot oem fb_mode_set fastboot flash partition gpt.bin fastboot flash bootloader bootloader.img fastboot flash logo logo.bin fastboot flash boot boot.img fastboot flash recovery recovery.img fastboot flash dsp adspso.bin fastboot flash oem oem.img fastboot flash system system.img_sparsechunk.0 fastboot flash system system.img_sparsechunk.1 fastboot flash system system.img_sparsechunk.2 fastboot flash system system.img_sparsechunk.3 fastboot flash system system.img_sparsechunk.4 fastboot flash system system.img_sparsechunk.5 fastboot flash system system.img_sparsechunk.6 fastboot flash system system.img_sparsechunk.7 fastboot flash system system.img_sparsechunk.8 fastboot flash modem NON-HLOS.bin fastboot erase modemst1 fastboot erase modemst2 fastboot flash fsg fsg.mbn fastboot erase cache fastboot erase userdata fastboot erase customize fastboot erase clogo fastboot oem fb_mode_clear fastboot reboot | |
10-10-2019, 15:25 | #8 (permalink) | |
Cheater -Don't Deal with him- Join Date: Mar 2012
Member: 1728299 Status: Offline Thanks Meter: 7 | Quote:
use this tool works perfect | |
10-10-2019, 15:48 | #9 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Samsung
Member: 10028 Status: Offline Sonork: n/a Thanks Meter: 840 | try flashing this firmware: https://mirrors.lolinet.com/firmware...LT_CFC.xml.zip |
10-11-2019, 06:25 | #10 (permalink) | |
so kindly check the info before posting Best Regards Sagar Jaiswal Press Thanks If Helped | |
The Following User Says Thank You to sagarjais For This Useful Post: |
10-14-2019, 21:03 | #13 (permalink) |
Member: 22869 Status: Offline Thanks Meter: 132 | hello guys, no difference between RETAIL or RETEU flashing, both accepted by phone Found something strange, after flashing but before reboot, getvar all shows: flashing DEEN_RETAIL_9.0_PPKS29.68-16-36-7.... (bootloader) slot-bootable:_a: Yes (bootloader) slot-bootable:_b: Yes (bootloader) slot-retry-count:_a: 7 (bootloader) slot-retry-count:_b: 0 fastboot reboot getvar all (bootloader) slot-bootable:_a: No (bootloader) slot-bootable:_b: No so far not found the solution, anyone can repair remotely please send PM |
01-29-2022, 01:17 | #14 (permalink) | |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | no a/b slot Quote:
:\Program Files (x86)\Minimal ADB and Fastboot>fastboot getvar all (bootloader) version: 0.5 (bootloader) version-bootloader: MBM-2.1-deen_retail-6f8d34a-190128 (bootloader) product: deen (bootloader) board: deen (bootloader) secure: yes (bootloader) hwrev: PVT1 (bootloader) radio: 2 (bootloader) storage-type: emmc (bootloader) emmc: 64GB SAMSUNG RH64AB RV=08 PV=05 FV=0000000000000005 (bootloader) ram: 4GB SAMSUNG LP3 DIE=8Gb M5=01 M6=06 M7=00 M8=5F (bootloader) cpu: MSM8953 (bootloader) serialno: ZL5228FXC9 (bootloader) cid: 0x0032 (bootloader) channelid: 0x29 (bootloader) uid: AE64A4A600000000000000000000 (bootloader) securestate: oem_locked (bootloader) iswarrantyvoid: no (bootloader) max-download-size: 534773760 (bootloader) reason: Fall-through from normal boot mode (bootloader) imei: 3555460907 (bootloader) meid: (bootloader) date: 09-18-2018 (bootloader) sku: XT1941-5 (bootloader) carrier_sku: XT1941-5 (bootloader) battid: SB18C30734 (bootloader) iccid: (bootloader) cust_md5: (bootloader) max-sparse-size: 268435456 (bootloader) current-time: "Sun Dec 16 17: 4:59 UTC 2018" (bootloader) ro.build.fingerprint[0]: motorola/deen/deen_sprout:9/PPKS29 (bootloader) ro.build.fingerprint[1]: .68-16-21-2/99791:user/release-key (bootloader) ro.build.fingerprint[2]: s (bootloader) poweroffalarm: 0 (bootloader) ro.build.version.full[0]: Blur_Version.39.221.3.deen.retail (bootloader) ro.build.version.full[1]: .en.US (bootloader) ro.build.version.qcom: LA.UM.7.6.r1-02500-89xx.0 (bootloader) version-baseband: M8953_16.15.02.19R DEEN_LATAM_CUST (bootloader) kernel.version[0]: Linux version 3.18.115-perf-g9f9181a (hu (bootloader) kernel.version[1]: dsoncm@ilclbld67) (gcc version 4.9.x 201 (bootloader) kernel.version[2]: 50123 (prerelease) (GCC) ) #1 SMP PREEMP (bootloader) kernel.version[3]: T Thu Dec 27 09:26:21 CST 2018 (bootloader) sbl1.git: sbl1.git (bootloader) rpm.git: rpm.git (bootloader) tz.git: tz.git (bootloader) devcfg.git: devcfg.git (bootloader) keymaster.git: keymaster.git (bootloader) cmnlib.git: cmnlib.git (bootloader) cmnlib64.git: cmnlib64.git (bootloader) prov.git: prov.git (bootloader) aboot.git: MBM-2.1-deen_retail-6f8d34a-190128 (bootloader) frp-state: protected (77) (bootloader) ro.carrier: openmx (bootloader) current-slot: (bootloader) running-boot-lun: 0 (bootloader) running-slot: (bootloader) slot-suffixes: _a,_b (bootloader) slot-count: 2 (bootloader) slot-successful:_a: No (bootloader) slot-successful:_b: No (bootloader) slot-bootable:_a: No (bootloader) slot-bootable:_b: No (bootloader) slot-retry-count:_a: 0 (bootloader) slot-retry-count:_b: 0 all: listed above finished. total time: 0.445s | |
