Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Motorola > Motorola Android based phones
Motorola Android based phones General Motorola Android phones discussion, firmwares, solution, root, help
Old 06-18-2010, 22:36   #1 (permalink)
dawah telecom's Avatar
Member: 868940
Motorola A855 activation problem....
hello..m8,i av Motorola A855 verizon.......it hangs on start up, and i make hard reset to make it work perfectly....now its require Ativation....
now, since the phone is simless, how can i make it activated.....cos it need to connect to server to make it activate.
Q: How to activate motorola A855 "verison" ????
br
dawah telecom
Old 09-16-2010, 19:50   #2 (permalink)
Member: 525755
activate motorola A855 in this link Performing initial activation and setup - Motorola Droid (A855)
Old 09-16-2010, 19:53   #3 (permalink)
Member: 525755
From the initial activation screen, touch the android.
Touch Activate.
Listen to the instructions, touch 1, then stay on the line until activation confirmation is heard.
Touch Next.
Touch Begin.
Touch Next.
Touch Next.
Touch the desired option:
Create
Sign in
Skip
Create Google Account
Slide the keyboard to the open position.
Enter the Google account information then select Next.
First name
Last name
Unique desired username
Enter the desired password, re-enter the password then select Next.
Select the Security question field.
Select the desired security question.
Enter the desired answer to the selected security question then select Create.
Review the Google Terms of Service then select I agree, Next.
Enter the characters that are seen in the picture then select Next.
Slide the keyboard back to the closed position.
If desired, ensure the following options are checked then touch Next.
Allow Google's location service to collect anonymous location data. Collection will occur when no applications are running
Allow Google to use location for improved search results and other services.
If desired, ensure Back up settings to my Google Account is checked then touch Next.
To enable Back up my settings to my Google Account at a later time, refer to Backing up settings to Google servers - Motorola Droid (A855).
Touch Finish setup.
Top
Sign in to existing Google account
Username
Password
Touch Next.
Top
Skip Google account setup
Old 02-25-2011, 21:53   #4 (permalink)
Member: 106488
y try to active in other country man
how to skip that ? how to active in other country?
The Following User Says Thank You to fantomasv For This Useful Post:
Old 03-20-2011, 05:22   #5 (permalink)
Member: 1539948
when the green robot appear on screen, tap the 4 corners starting from the top-left corner and going clock wise with the other 3, you will be send to the idle screen, then dial *#setup* to enter MIN and NAM
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
GId1 problem old_man Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 10-18-2006 15:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-21-1999 18:43
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-11-1999 17:39
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-16-1999 00:44
Page generated in 0.34391 seconds with 11 queries
