Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
11-01-2013, 04:14 | #2 (permalink) |
Freak Poster Join Date: Oct 2009 Location: {INDIA * UAE}
Member: 1134306 Status: Offline Thanks Meter: 133 | Turn off the Droid. If you are unable to turn off the Droid, remove the battery for 10 seconds, then replace it. Open the physical keyboard and press the X key while pressing and holding the Power Button. The device will turn on, keep holding these two buttons until a yellow triangle appears. Press the Volume Up and then the Camera button at the same time to get a menu to come up. You may have to press them more then once. You have now entered Recovery Mode. Use the Directional Pad on the Physical Keyboard to select the Format option. |
The Following User Says Thank You to F Alam86 For This Useful Post: |
