Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Android based
Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help
Old 10-02-2016, 13:15   #1 (permalink)
Member: 334225
Thanks Meter: 65
motorola droid turbo xt1254 frp reset
motorola droid turbo xt1254 frp reset plz help me i have tried all method of you tube is there any new way plz plz help me
Old 10-03-2016, 02:13   #2 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,729
Solution Tested:
ByPass:
1. Playing in email and keep pressed the @ until a menu of options.
2. keyboard settings Google
3. orthographic / staff / Dictionary correction for all languages
4. On the next screen tap the magnifying glass and press the letter "c". Several options were deployed and there
Google Pinyin Input to choose. On the next screen we chose the same option.
5. Then choose "about" Open Source Licenses"
6. On the next screen may maintain finger pressing and the option will appear
"Share" to choose "messages" typing 112 and send. At that time the call keyboard appears
delete 112 and type * # * # 4636 # * # *
7. On the next screen you can choose info or battery usage statistics.
8. Then go to back with the arrow on the top left
9. ByPass done.
10. Here you can not enable the developer and we can not restore option. It's just bypass
Process FRP
- Download four app
- Aptoide
- Es fileExplorer
- Kingo Root
- Terminal Emulator
1. In the menu go to Use data / You Tube / Application Settings / About
2. chose Google Privacy Policy
3. Open Google Chrome and from there download each of the applications but do not open.
4. Then return to the phone menu with the option "back"
5. We will install fromStorage File Explorer and open it
6. From the File Explorer install the other three applications
7. Open Aptoide and install the Nova Launcher, open and see the phone menu
8. Execute Kingo Root and Root and wait to tell you Done
9. Let back and look for the Terminal Emulator, enter and type "SU" to give us the option
root access #
10. Write in the amulador the following command:
content insert --uri content://settings / secure --bind name: s: user_setup_complete --bind value: s: 1
11. After that go back out from terminal emulator. Enable developer and OEM Unlockif not does not imortant.
12. Go to account and fill your own google account. The phone let you fil up.
13 Very importante do no delete the phone
14. Restart the phone and when start again you can enter your own google account. Then delete the phone.
The Following 2 Users Say Thank You to gcceleghg For This Useful Post:
Old 10-03-2016, 02:15   #3 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,729
Another solution here:
Motorola Droid Turbo XT1254 FRP SOLVED ? Samsung Cert Files. Combination files. FRP Remove Solutions
Old 11-03-2016, 07:41   #4 (permalink)
Member: 1555233
Thanks Meter: 29
Error
SEPTEMBER 15, 2016SOLUTIONSTAGGED SAMSUNG COMBINATION FILESBY FACTORY SUPPORT
HI THERE
TODAY WE GONNA SHOW YOU HOW TO REMOVE GOOLGE ACCOUNT FROM*Motorola Droid Turbo XT1254 ITS REALLY EASY JUST FOLLOW THE FOLLOWING STIPS*
FOLLOW THE YOUTUBE TO GET INTO SETTING AND INSTALL APPS*
DOWNLOADS :*http://theroot.ninja/apks/SunShine-latest.apk* **
Terminal Emulator 1.0.70 APK Download by Jack Palevich - APKMirror
KingRoot 4.9.3 (144) APK Download by KingRoot Studio - APKMirror
Note: PUT these files on your memory card with OTG Cable.
STEP 1: Install Sunshine APP and Temporary Root your Mobile or Use any other Tool for Rooting Your Mobile
STEP 2: RUN THE KINGO ROOT APK TO ROOT DEVICES THIS WILL FAIL BUT HAVE TO TRY MANY TIMES AND FINALY YOU GET SUCCESS
STEP 3:*Install Terminal APP and OPEN *AND TYPE THESE COMMANDS*
1: su
2: content insert –uri content://settings/secure –bind name:s:user_setup_complete –bind value:s:1
TIP : THE BETTER WAY IS TO COPY THIS COMMAND (*content insert –uri content://settings/secure –bind name:s:user_setup_complete –bind value:s:1) IN TEXT FILE AND THEN RUN VIA ES FILE EXPLOLER ESN EDITOR AND COPY AND PAST IN TERMINAL …
STEP 4 : AFTER COMMANDS GOTO SETTING AND MAKE RESET *YOUR DONE*
IF ANY ISSUE LET ME KNOW*
ERROR
(ERROR) Unsupported argument. uri
Old 11-03-2016, 07:54   #5 (permalink)
scorpian1982's Avatar
Member: 2192793
Thanks Meter: 169
HI THERE
1: su
ERROR
My dear this is not as simple as you are saying. me and all other users have try this solution but no success. i have try this more then 200 time to root but. . .
there is no solution yet for this model.
Old 11-04-2016, 07:32   #6 (permalink)
Member: 1555233
Thanks Meter: 29
Set root no problem
su boot ok
This file error
Old 11-06-2016, 22:16   #7 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 942
su boot ok
This file error
Your command is wrong just enter "content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1"
Motorola Droid Turbo FRP remove commands.
Install Terminal.apk and open it.
Type “su” in terminal and hit Enter on keyboard.
Then type second command correctly “content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1” and hit Enter.
The second command will bypass activation process and activate phone to normal. now you can add you account and can reset Motorola droid turbo from setting.
For detailed instruction visit this post i have done a phone yesterday and posted there.
The Following User Says Thank You to >>PakFones<< For This Useful Post:
Old 11-14-2016, 15:16   #8 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 942
Hi friends i have made a post here in Motorola section just check it out.[Guide] How To Bypass Google Account Motorola Droid Turbo XT1254 New Security 2016
Old 11-28-2016, 01:03   #9 (permalink)
Member: 1024853
Thanks Meter: 24
See This video and Complete guide step by step files links are available under video desciption.
https://www.youtube.com/watch?v=2QzSPpufKzM&t=16s
Old 01-08-2017, 05:44   #10 (permalink)
Member: 1015645
Thanks Meter: 113
HI THERE
1: su
ERROR
COMPLETE FOLLOW ABOVE INSTRUCTION BUT SHOW THIS ERROR ANY EXPERT SOLUTION GIVE ME
Old 01-09-2017, 20:28   #11 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 942
Don't worry we have discovered google account bypass solution for all Motorola running android 6.0.1 android security patch level 1 September 2016. Just this link for full detail. or watch youtube video directly. Don't forget to subscribe our youtube channel you will also get some exclusive videos from pakfones.
Old 11-17-2019, 12:23   #12 (permalink)
Member: 1159475
Sonork: multan
Thanks Meter: 51
Motorola 1254 FRP Unlock Easy Way one Click FRP
https://www.youtube.com/watch?v=g0xhCTMv4Tk
Page generated in 0.41920 seconds with 7 queries
