Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
08-18-2010, 12:35 | #3 (permalink) |
No Life Poster Join Date: Nov 2009 Location: BaNgLaDeSh Age: 41
Member: 1150957 Status: Offline Thanks Meter: 60 | Motorola CLIQ XT (MB501) Hard Reset: 1. Turn the power off. If your Motorola CLIQ XT is frozen, pull the battery out and reinsert it 2. Press and hold the Power and Camera buttons 3. Release the Camera button when prompted 4. Press and hold the Volume Down key 5. A yellow exclamation will appear on the display. Wait until a menu with options will appear. 6. Using the touch screen select Factory Reset and press OK. That's all. |
The Following 3 Users Say Thank You to brokendreem For This Useful Post: |
08-19-2010, 01:21 | #5 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: NYC
Member: 416710 Status: Offline Thanks Meter: 391 | Quote:
http://forum.gsmhosting.com/vbb/6222067-post37.html | |
08-19-2010, 06:07 | #6 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: JSR, BD
Member: 310155 Status: Offline Thanks Meter: 1,313 | Quote:
Try this, work 100%, tested by me. hope u'll be happy How do I perform a hard reset? -------------------------------- 1.Press the menu key and turn on the phone. 2.Press the 'camera' key and 'power' key simultaneously and hold till the Moto batwing screen goes away and you will see a message on the screen to release the 'camera' key. 3.User will see option to get into recovery mode. 4.Press Volume down key to get into recovery mode. 5.Once in the recovery mode, tap on the right lower corner of the touchscreen(might have to tap a few times). 6.'Motorola system recovery' menu will come up. 7.User can use the mini pad or tough screen and select wipe data/factory reset to do a factory reset. 8.Select 'ok' at the lower left corner once the intended menu item has been selected. 9.Use the mini pad to scroll up and select reboot system now 10.Press OK | |
The Following 10 Users Say Thank You to reaz.com For This Useful Post: |
08-19-2010, 06:35 | #7 (permalink) | |
No Life Poster Join Date: Feb 2008
Member: 708514 Status: Offline Thanks Meter: 36 | Quote:
BIG Thanks, yes i am verry happy. phone is working now. | |
The Following User Says Thank You to TheFoXMK For This Useful Post: |
12-08-2010, 19:14 | #9 (permalink) |
Junior Member Join Date: Dec 2010
Member: 1463023 Status: Offline Sonork: Jesús Geovanni Thanks Meter: 0 | thanks for you big need!!! :) Try this, work 100%, tested by me. hope u'll be happy How do I perform a hard reset? -------------------------------- 1.Press the menu key and turn on the phone. 2.Press the 'camera' key and 'power' key simultaneously and hold till the Moto batwing screen goes away and you will see a message on the screen to release the 'camera' key. 3.User will see option to get into recovery mode. 4.Press Volume down key to get into recovery mode. 5.Once in the recovery mode, tap on the right lower corner of the touchscreen(might have to tap a few times). 6.'Motorola system recovery' menu will come up. 7.User can use the mini pad or tough screen and select wipe data/factory reset to do a factory reset. 8.Select 'ok' at the lower left corner once the intended menu item has been selected. 9.Use the mini pad to scroll up and select reboot system now 10.Press OK |
02-21-2011, 18:46 | #12 (permalink) |
No Life Poster Join Date: Jan 2006 Location: ES-Brazil
Member: 217679 Status: Offline Thanks Meter: 95 | How to put on MB501 Motorola flash mode or boot, he just gets caught in the logo "M" after he tried to make a flash error and gave the Scout, and now will not accept any flash, just displays the same error. SCout 1.33. Flashing phone MB501 flex "USAZEP01TMOBNA018.0R" with firmware "secure-MB501_0.12.11_1.32.24-super*******-customer.pcf" RAM DL 5.13... Loading file "secure-MB501_0.12.11_1.32.24-super*******-customer.pcf"... OK Switching to flash mode... Unable to retrieve phone interface Switching to flash mode... Flash completed with error/warning: Flash library error 39 |
The Following User Says Thank You to cbcelular For This Useful Post: |
02-24-2011, 17:09 | #14 (permalink) | |
Junior Member Join Date: Jun 2008 Location: R.D.
Member: 801839 Status: Offline Thanks Meter: 4 | Quote:
G.M. 's GSM Links Nokia Siemens Trium Motorola Sagem | GM | GSM Mobile Links | 0 | 06-18-2000 09:04 |
Updated site... Motorola BOX, Nokia Clip... | mihut | GSM Mobile Links | 0 | 05-29-2000 02:52 |
I have unlcoker for 51/61/32 for all new version for exchange Motorola 3*88 unlocker! | MC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-14-1999 13:02 |
Soft for Motorola with cable... | florin_m | GSM Mobile Links | 3 | 10-11-1999 14:44 |
Ericsson-Motorola-Siemans unlock solutions | dave | GSM Mobile Links | 0 | 08-27-1999 19:46 |
