Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Android based
Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help
Old 04-25-2013, 07:01   #1 (permalink)
vicky_tomar's Avatar
Member: 1740430
Sonork: 100.1627542
Thanks Meter: 198
Arrow motorola mb853 factory reset
how to motorola_mb853 _factory reset plzzzzzzz help me
Old 04-25-2013, 07:58   #2 (permalink)
.::EXTREME::.'s Avatar
Member: 1619462
Sonork: 100.1606509
Thanks Meter: 1,517
Try this methode...
To Perform a factory reset using external keys
1. Power up the phone by pressing the VOL UP + VOL DOWN KEY together + POWER KEY .
2. The device will enumerate with different BOOT OPTIONS
3. Use the VOL DOWN Key to SCROLL and VOL UP Key to SELECT
4. Select Recovery
5. The device will start up with Motorola logo and power up to a little Android man logo with Exclamation mark
6. Press the VOL UP and VOL DOWN Key together at this screen
7. The device will display BLUE Text on a Black background .
8. Use the VOL DOWN Key to scroll DOWN and the POWER Key to SELECT the option desired .
9. In this case , press the VOL DOWN key till the Wipe data / factory reset is selected and press the POWER key to confirm the selection .
10. Use the VOL DOWN key again to select YES - delete all user data and press the POWER key to CONFIRM .
11. The device will then start performing the Factory Data Reset
12. Once the Formatting is complete , press the POWER key to confirm a REBOOT
13. The message rebooting is displayed on the phone.
14. The device will reboot and start the normal power up sequence .
Post me result.
If its DONE. Dont Forget to Press Thanks
The Following User Says Thank You to .::EXTREME::. For This Useful Post:
Old 03-05-2014, 11:45   #3 (permalink)
Member: 2131906
Sonork: 1653000:esQmo
Thanks Meter: 16
It doesn't work! it's displaying Starting RSD protocol support
The Following User Says Thank You to esQmo For This Useful Post:
Old 03-17-2014, 20:06   #4 (permalink)
dan0007's Avatar
Member: 38050
Thanks Meter: 61
Right way motorola mb853 factory reset
1 Power off the phone, press and hold volume down button, press power button
2 Screen will come up with "Fastboot", press Vol down key to cycle through choices until you get "Android Recovery", then press Vol up key
3 Wait for the "triangle ! / Android" screen then go on to step 4
4 Press both Vol up and Vol down key simultaneously. A menu will come up
5 Tap on Vol down key until "wipe data/factory reset" is highlighted, and tap Power key. Another Confirmation screen will come. Tap on Vol down key until coming to Yes and tap Power key
6 After userdata is cleared, the "reboot system now" option will be highlighted by Default. Tap Power key
7 Phone will reboot to initial setup screen.
Post me result.
The Following User Says Thank You to dan0007 For This Useful Post:
Old 10-15-2014, 13:00   #5 (permalink)
Member: 2254855
Thanks Meter: 2
Thumbs up nice job
i have tried this steps and it workout
Page generated in 0.15285 seconds with 8 queries
