Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
07-10-2016, 13:52 | #3 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Tried with code * # * # 4636 # * # * and all, here I leave a solution, You have to do the following: 1-turn on the device and select our language and press Start 2- then pressed in using Wi-FI 3-select our network and we give below 4-now we pressed on Privacy Settings 5-entered see the privacy policy motorola 6-pressed in any of the texts in sky 7-hold down 3 seconds or more to highlight the text will no bar to cut, copy, share and search we chose to seek 8-a selected see the search option and we write set appear as in the second image we give to configure 9-not headed to About Phone 10, we will build number and press to have permission 11 return to the previous menu and select programmer 12, activate the option Developer 13- And finally the usb debugging 14-connect the device to the PC and we will get a warning and tildamos Always allow from this computer 15- Now we unzip the downloaded file open the Moto Auto Flash Tool v6.6 By Jamesjerss folder 16- run the Moto Auto Flash Tool v6.6 By Jamesjerss file and leave us like in the picture, then we press any key 17-we choose option 6 18, option 2 and then waited a second and ready your device is unlocked Here the link file: https://mega.nz/#!4EAiUDiC encryption key: qIDWv1BqLcb_LF_11h_qxoXXGGpmdBfSf7nUgCvN6kI |
07-10-2016, 13:55 | #4 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Other solution: Try to follow this process for the model XTxxxx in 5.1.1 but although I got to the configuration, to "build number" played 7 or 10 times and nothing ..... I think this phone user had locked and would not let developing mode. The solution to circumvent the FRP 5.1.1 (patch 03/01/2016). I thought I would share while fighting to find a way around for this model and see several different methods all over the web without result. XT1506 tested but may work for other models. Previous requirements: Adb work environment. Driver Installation. 1. Put the phone in Fastboot Mode (vol- and power button) and connect to the PC via USB. 2. Use vol down to scroll to 'QCOM' and select up to vol. 3. After restarting the phone, it re begins in the phone screen, and select OK. 4. Open command open ADB system, and enter the following code: Code: adb shell content insert --uri content: // settings / secure --bind name: s: user_setup_complete --bind value: s: 1 This should complete the setup wizard. 5. You now have full access to the configuration menu and backup and restore> Reset Data Factory> Reset phone is no longer gray. Select the option, let the phone reboot and now you can set the phone as new. Select QCOM, it was what enabled the USB debugging. |
07-10-2016, 18:56 | #5 (permalink) | |
No Life Poster Join Date: Sep 2015 Location: Earth
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | Quote:
i tried many times to find driver on Qcomn mod but there is no driver for it on window 8 Sent from my iPhone using Tapatalk | |
07-10-2016, 22:45 | #6 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Moto G (1st Generation) You’ve got the device. We’ve got the tools to help. How-to’s, forums, live support and so much more. https://motorola-global-portal.custh...p/30,6720,9050 |
01-09-2017, 09:45 | #9 (permalink) | |
Freak Poster Join Date: May 2009
Member: 1041401 Status: Offline Thanks Meter: 14 | Quote:
this method notworking for me it has andriod 6.0.1 any other solution plz help me | |
01-09-2017, 20:21 | #10 (permalink) |
No Life Poster Join Date: Jul 2007 Location: My Computer
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | Here it is latest security solution till December 2016 for all Motorola running security patch level 1 September 2016 or lower. may this will also work on later one. https://goo.gl/lbGNBZ https://www.youtube.com/watch?v=ipiG_G7eTQc |
01-21-2017, 18:29 | #11 (permalink) | |
Insane Poster Join Date: Mar 2012 Location: pakistan, islamabad/lahore
Member: 1729557 Status: Offline Sonork: 100.1677910 Thanks Meter: 5 | * # * # 4636 # * # * Quote:
* # * # 4636 # * # * this code is not working in verizon | |
01-21-2018, 11:48 | #14 (permalink) |
Freak Poster Join Date: Mar 2008 Location: pakistan
Member: 730479 Status: Offline Sonork: [email protected] Thanks Meter: 24 | only cm2 is best for motorola xt1096 frp locked remover. |
