Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
07-27-2014, 07:26 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Location: Philippines
Member: 100065 Status: Offline Thanks Meter: 39 | Motorola xt909 IS12M brick need help |
08-02-2014, 04:45 | #3 (permalink) |
Member: 100065 Status: Offline Thanks Meter: 39 | Problem solve Screen Shot below http://postimg.org/image/u75yqdulz/ http://postimg.org/image/d7x0b4jef/ http://postimg.org/image/dgpznb6t3/ http://postimg.org/image/8jh0fxu7r/ http://postimg.org/image/dlycaq3hz/ http://postimg.org/image/6c86e9zjr/ steps that I made 1st step ===>>I download"DROID_RAZR_Utility_Jellybean_XT912_WinMacLin.zip" then extract and flash the unit...but it gives me more headache "Invalid Flash Mode (S) (Boot Failure) 0A.77 eMMC Info: Size 16G To return to normal mode - first press power key to power down Device is LOCKED. Status Code: 0 Battery OK OK to Program Transfer Mode: USB Connected Invalid CG OTV (CG: system): Invalid SP Data Invalid CG HAB (CG: system, status: 0x0056) Invalid CG OTV (CG: system)" 2nd step I download "Blur_Version.65.3.18.IS12M" then extract and flash the unit using this firmware "Blur_Version.65.3.18.IS12M" "I used RSDLIT for flashing" but I am always getting error flashing with RSDLITE until the battery got totally drained NOTE: with this unit I learned that it can't be charged if the software was tptally damage even you use BPTOOLS to charge it. So what I did was find an old and damage 5130 USB cable, since it was damage i repair it first the black and red cable was connected directly to the + and - of the battery and charge it for 8hrs using a cheap USB chagrer... then flash it again using RSDLITE but it was still giving me error...so I get back to "DROID_RAZR_Utility_Jellybean_XT912_WinMacLin.zip" flashing was complete but I got error "Invalid Flash Mode (S) (Boot Failure) 0A.77 eMMC Info: Size 16G To return to normal mode - first press power key to power down Device is LOCKED. Status Code: 0 Battery OK OK to Program Transfer Mode: USB Connected Invalid CG OTV (CG: system): Invalid SP Data Invalid CG HAB (CG: system, status: 0x0056) Invalid CG OTV (CG: system)" Until I come to a decission to do a little modifacation to "DROID_RAZR_Utility_Jellybean_XT912_WinMacLin" then after a little modification I flash again the unit using "DROID_RAZR_Utility_Jellybean_XT912_WinMacLin...Edi ted version by me" anf viola the problem was solve hehehehe. cheers note: the phone can be power normally and everything was 100% working |
08-19-2014, 08:11 | #4 (permalink) | |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | Quote:
08-28-2014, 04:42 | #5 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Philippines, iloilo city
Member: 1453900 Status: Offline Thanks Meter: 74 | hello sir smasher-x, can u plz upload the one you edit firmware i have one here its almost a week on me i tried hard reset but no luck.. wbr, *miguel05_gsm* |
