Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Android based
Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help
Old 07-27-2014, 07:26   #1 (permalink)
Member: 100065
Thanks Meter: 39
Motorola xt909 IS12M brick need help
brothers I need help for this phone it was stock on logo I google the solution and found this file "DROID_RAZR_Utility_Jellybean_XT912_WinMacLin" I followed the instruction carefully but I end up with an error now the phone was totally brick and the battery wont charge anymore. I google again and found this file "VRZ_XT912_6.5.1-73_DHD-11_TA-3_1FF_02.xml_3.zip" O want to flash it with this file but the phone was unable to program because too low battery...can someone give a help on how to unbrick this phone?
Old 07-28-2014, 08:27   #2 (permalink)
Member: 100065
Thanks Meter: 39
up this thread please help
Old 08-02-2014, 04:45   #3 (permalink)
Member: 100065
Thanks Meter: 39
Problem solve
Screen Shot below
http://postimg.org/image/u75yqdulz/
http://postimg.org/image/d7x0b4jef/
http://postimg.org/image/dgpznb6t3/
http://postimg.org/image/8jh0fxu7r/
http://postimg.org/image/dlycaq3hz/
http://postimg.org/image/6c86e9zjr/
steps that I made
1st step ===>>I download"DROID_RAZR_Utility_Jellybean_XT912_WinMacLin.zip" then extract and flash the unit...but it gives me more headache
"Invalid Flash Mode (S) (Boot Failure)
0A.77
eMMC Info: Size 16G
To return to normal mode - first press power key to power down
Device is LOCKED. Status Code: 0
Battery OK
OK to Program
Transfer Mode:
USB Connected
Invalid CG OTV (CG: system): Invalid SP Data
Invalid CG HAB (CG: system, status: 0x0056)
2nd step I download "Blur_Version.65.3.18.IS12M"
then extract and flash the unit using this firmware "Blur_Version.65.3.18.IS12M" "I used RSDLIT for flashing"
but I am always getting error flashing with RSDLITE until the battery got totally drained
NOTE: with this unit I learned that it can't be charged if the software was tptally damage even you use BPTOOLS to charge it.
So what I did was find an old and damage 5130 USB cable, since it was damage i repair it first
the black and red cable was connected directly to the + and - of the battery and charge it for 8hrs using a cheap USB chagrer...
then flash it again using RSDLITE but it was still giving me error...so I get back to "DROID_RAZR_Utility_Jellybean_XT912_WinMacLin.zip" flashing was complete but I got error
0A.77
eMMC Info: Size 16G
Battery OK
OK to Program
Transfer Mode:
USB Connected
Until I come to a decission to do a little modifacation to "DROID_RAZR_Utility_Jellybean_XT912_WinMacLin"
then after a little modification I flash again the unit using "DROID_RAZR_Utility_Jellybean_XT912_WinMacLin...Edi ted version by me" anf viola the problem was solve hehehehe. cheers
note: the phone can be power normally and everything was 100% working
Old 08-19-2014, 08:11   #4 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,126
Originally Posted by smasher-x View Post
Problem solve
Screen Shot below
View image: IMG 1762
View image: IMG 1763
View image: IMG 1767
View image: IMG 1770
View image: IMG 1772
View image: IMG 1774
steps that I made
0A.77
eMMC Info: Size 16G
Battery OK
OK to Program
Transfer Mode:
USB Connected
0A.77
eMMC Info: Size 16G
Battery OK
OK to Program
Transfer Mode:
USB Connected
do u like to share files with us..or can u tell how us how to modify?
Old 08-28-2014, 04:42   #5 (permalink)
*miguel05_gsm*'s Avatar
Member: 1453900
Thanks Meter: 74
hello sir smasher-x, can u plz upload the one you edit firmware i have one here its almost a week on me i tried hard reset but no luck..
wbr,
*miguel05_gsm*
Old 09-02-2014, 09:57   #6 (permalink)
Member: 1453900
Thanks Meter: 74
up for this tread need for this firmware hope u can help me..
wbr,
*miguel05_gsm*
Old 09-02-2014, 13:59   #7 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,126
XT909 IS12M unbrick solution | Droid RAZR | XDA Forum
Page generated in 0.19675 seconds with 8 queries
