Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
02-23-2017, 12:02 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Need working rom for xt925 I TRY THE FOLLOWING FILES Code: 9.8.2Q-50-XT925_VQLM-21_Retail_BR_SIGNED_S12_USAVANQURETBRLA020.0R_S1FF_CFCv2_fb.xml 9.8.2Q-8-XT925_VQU-22_USERSIGNED_S7_UCAVANQU02NA02F.0R_LSAVNQJBRTFR_P007_A004_CFC.xml 9.8.2Q-50-XT925_VQLM-20_AmericaMovil_BR_SIGNED_S12_USAVANQUCLABRLA01F.0R_VANQJBCLABRLA_P007_A007_S1FF_v2_fb.xml 7.7.1Q-144_VQL_S3-49_BR_LATAM_VANQUISHCLABRLA_Service1FF_fastboot.xml Code: The system cannot find message text for message number 0x2350 in the message file for Application. (c) 2015 Microsoft Corporation. All rights reserved. Not enough storage is available to process this command. E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-925\xt925>fastboot oem fb_mode_set ... OKAY [ 0.008s] finished. total time: 0.011s E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-925\xt925>fastboot flash partition gpt.bin (bootloader) Variable not supported! target reported max download size of 31457280 bytes error: cannot load 'gpt.bin': No error E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-925\xt925>fastboot flash motoboot motoboot.img (bootloader) Variable not supported! target reported max download size of 31457280 bytes error: cannot load 'motoboot.img': No error E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-925\xt925>fastboot flash logo logo.bin (bootloader) Variable not supported! target reported max download size of 31457280 bytes error: cannot load 'logo.bin': No error E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-925\xt925>fastboot flash boot boot.img (bootloader) Variable not supported! target reported max download size of 31457280 bytes error: cannot load 'boot.img': No error E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-925\xt925>fastboot flash recovery recovery.img (bootloader) Variable not supported! target reported max download size of 31457280 bytes error: cannot load 'recovery.img': No error E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-925\xt925>mfastboot flash system system.img DNS server not authoritative for zone. E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-925\xt925>fastboot flash modem NON-HLOS.bin (bootloader) Variable not supported! target reported max download size of 31457280 bytes error: cannot load 'NON-HLOS.bin': No error E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-925\xt925>fastboot erase modemst1 (bootloader) Variable not supported! erasing 'modemst1'... OKAY [ 0.780s] finished. total time: 0.786s E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-925\xt925>fastboot erase modemst2 (bootloader) Variable not supported! erasing 'modemst2'... OKAY [ 0.791s] finished. total time: 0.794s E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-925\xt925>fastboot flash fsg fsg.mbn (bootloader) Variable not supported! target reported max download size of 31457280 bytes error: cannot load 'fsg.mbn': No error E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-925\xt925>fastboot erase cache (bootloader) Variable not supported! erasing 'cache'... OKAY [ 1.222s] finished. total time: 1.224s E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-925\xt925>fastboot erase userdata (bootloader) Variable not supported! erasing 'userdata'... OKAY [ 7.332s] finished. total time: 7.335s E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-925\xt925>fastboot erase customize (bootloader) Variable not supported! erasing 'customize'... (bootloader) Invalid partition name customize FAILED (remote failure) finished. total time: 0.024s E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-925\xt925>fastboot erase clogo (bootloader) Variable not supported! erasing 'clogo'... (bootloader) Invalid partition name clogo FAILED (remote failure) finished. total time: 0.026s E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-925\xt925>fastboot oem config carrier vzw ... FAILED (remote failure) finished. total time: 0.019s E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-925\xt925>fastboot oem fb_mode_clear ... OKAY [ 0.006s] finished. total time: 0.007s E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-925\xt925> Code: F:\Backup Data\TORNADO\PRODUCTS\GSM_PRODUCTS\SAMSAUNG\Fastboot\Fastboot>fastboot getvar all (bootloader) version-bootloader: 1098(*) (bootloader) product: vanquish_u (bootloader) secure: yes (bootloader) mid: 0056 (bootloader) version: 0.5 (bootloader) serialno: TA26103GZ5 (bootloader) qe: qe 0/1 (bootloader) unlocked: no (bootloader) iswarrantyvoid: no (bootloader) max-download-size: 31457280 (bootloader) emmc-size: 32GB (bootloader) reason: Flash Failure (bootloader) revision-hardware: 0x8301 (bootloader) cpu: MSM8960 CS (bootloader) uid: 1DAD050202000100000000000000 (bootloader) cid: 0x02 all: finished. total time: 0.038s |
02-23-2017, 12:05 | #2 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | also try with xt-926 4.4.2 Code: VZW_XT926_4.4.2-KDA20.62-15.1_CFC_1FF.xml Code: The system cannot find message text for message number 0x2350 in the message file for Application. (c) 2015 Microsoft Corporation. All rights reserved. Not enough storage is available to process this command. E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-926\VZW_XT926_4.4.2-KDA20.62-15.1_CFC_1FF.xml>fastboot oem fb_mode_set ... OKAY [ 0.005s] finished. total time: 0.008s E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-926\VZW_XT926_4.4.2-KDA20.62-15.1_CFC_1FF.xml>fastboot flash partition gpt.bin (bootloader) Variable not supported! target reported max download size of 31457280 bytes sending 'partition' (32 KB)... OKAY [ 0.010s] writing 'partition'... FAILED (remote failure) finished. total time: 0.151s E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-926\VZW_XT926_4.4.2-KDA20.62-15.1_CFC_1FF.xml>fastboot flash motoboot motoboot.img (bootloader) Variable not supported! target reported max download size of 31457280 bytes error: cannot load 'motoboot.img': No error E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-926\VZW_XT926_4.4.2-KDA20.62-15.1_CFC_1FF.xml>fastboot flash logo logo.bin (bootloader) Variable not supported! target reported max download size of 31457280 bytes sending 'logo' (854 KB)... OKAY [ 0.076s] writing 'logo'... OKAY [ 1.306s] finished. total time: 1.389s E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-926\VZW_XT926_4.4.2-KDA20.62-15.1_CFC_1FF.xml>fastboot flash boot boot.img (bootloader) Variable not supported! target reported max download size of 31457280 bytes sending 'boot' (10240 KB)... OKAY [ 0.794s] writing 'boot'... OKAY [ 4.274s] finished. total time: 5.077s E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-926\VZW_XT926_4.4.2-KDA20.62-15.1_CFC_1FF.xml>fastboot flash recovery recovery.img (bootloader) Variable not supported! target reported max download size of 31457280 bytes sending 'recovery' (10240 KB)... OKAY [ 0.776s] writing 'recovery'... OKAY [ 3.248s] finished. total time: 4.034s E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-926\VZW_XT926_4.4.2-KDA20.62-15.1_CFC_1FF.xml>mfastboot flash system system.img DNS server not authoritative for zone. E:\TORNADO\PRODUCTS\GSM_PRODUCTS\MOTOROLLA\Firmwares\XT-926\VZW_XT926_4.4.2-KDA20.62-15.1_CFC_1FF.xml>fastboot flash modem NON-HLOS.bin (bootloader) Variable not supported! target reported max download size of 31457280 bytes Invalid sparse file format at header magi |
02-25-2017, 06:38 | #5 (permalink) | |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Quote:
boot-loader is locked i try with officially unlock but it was fail,mean not possible to unlock by officialese site.and which 4.4.2 version is suitable for me.???? | |
03-03-2017, 14:49 | #6 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Boot loader is almost locked and I try to officially unlock but I have no success from Motorola officials boot unlock site. Sent from my iPhone using Tapatalk |
