Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Android based
Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help
Old 11-23-2014, 23:07   #1 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Arrow Nexus 6 lollipop & Marshmallo Firmware Flashing Guide + Rooting (Updated 05/10/2015)
Nexus6 Lollipop Firmware & Flashing Guide
Install Drivers
Note:If driver already installed no need to install again.
Adb & fastboot 1 click Driver Download
Note: Before flash unlock yur bootloader after flash complete lock bootloader commds below
fastboot oem unlock
fastboot oem lock
Firmware Download
Nexus 6 International
Nexus 6 5.0 (LRX21O) Factory firmware
Nexus 6 5.0.1 (LRX22C) Factory firmware
Nexus 6 5.1.0 (LMY47I) Factory firmware
Marshmallow 6.0.0 (MRA58K)
Nexus 6 (T-Mobile ONLY)
Nexus 6 5.1.0 (LMY47M) Factory firmware
Nexus 6 5.1.1 (LYZ28E) Factory firmware
Nexus 6 (Sprint ONLY)
Nexus 6 5.1.1 (LMY47Z) Factory firmware
Flasing Guide
* Extract the firmware zip 1st
* After Extract yu vil get a single file
* Change tat files extension .tar or .rar (if change as rar use 7zip to extract it)
* Again extract it after change the Extension yu vil get files below given in the picture.
* Connect yur mob in fastboot mode
* Run the flash-all.bat
Rooting Guide Only for version 5.0
Root File For Nexus 6
Procedure:
* Enable usb debugging
* Settings Developer options > Enable OEM unlock
* Boot the Nexus 6 into bootloader mode via adb or hardware buttons
(press and hold Volume Down and Power buttons until
Fastboot/Bootloader menu and START icon appear on the screen).
* Connect the Nexus device to computer via USB cable.
*Unzip the CF-Auto-Root-shamu-shamu-nexus6.zip file on your computer.
For Windows: Run the root-windows.bat file.
Note: Before if not bootloader unlocked it vil unlock yur bootloader so take backup all files
DON'T SAY THANKSJUST PRESS BUTTON
BUTTON
The Following 21 Users Say Thank You to jamesjerss For This Useful Post:
Old 06-27-2015, 13:18   #2 (permalink)
Member: 569063
Thanks Meter: 25
i try to flash but shows erros any adeal
The Following 2 Users Say Thank You to ydizor For This Useful Post:
Old 06-27-2015, 21:33   #3 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
post error vit screen shot or give more info
The Following 2 Users Say Thank You to jamesjerss For This Useful Post:
Old 07-16-2015, 20:38   #4 (permalink)
Gambitv01's Avatar
Member: 1475064
Thanks Meter: 347
can we do imei repair on this currently?
The Following 2 Users Say Thank You to Gambitv01 For This Useful Post:
Old 07-16-2015, 21:54   #5 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Imei repair is not possible for now.
Old 09-02-2015, 19:30   #6 (permalink)
Member: 156994
Sonork: 100.1615423
Thanks Meter: 650
i tired all international firmwares i get this error
target reported max download size of 536870912 bytes
sending 'bootloader' (3807 KB)...
OKAY [ 0.130s]
writing 'bootloader'...
(bootloader) flashing partition ...
(bootloader) This may take a few seconds if a
(bootloader) different partition table is being
(bootloader) flashed since we need to backup
(bootloader) and restore a few partitions
(bootloader) Flashing primary GPT image...
(bootloader) Flashing backup GPT image...
(bootloader) flashing aboot ...
(bootloader) flashing sbl1 ...
(bootloader) flashing rpm ...
(bootloader) flashing tz ...
(bootloader) flashing sdi ...
(bootloader) flashing logo ...
OKAY [ 0.460s]
finished. total time: 0.590s
rebooting into bootloader...
OKAY [ -0.000s]
finished. total time: -0.000s
< waiting for device >
sending 'radio' (85422 KB)...
OKAY [ 2.690s]
writing 'radio'...
(bootloader) flashing modem ...
(bootloader) flashing mdm1m9kefs1 ...
(bootloader) flashing mdm1m9kefs2 ...
(bootloader) flashing mdm1m9kefs3 ...
(bootloader) flashing versions ...
OKAY [ 1.200s]
finished. total time: 3.890s
OKAY [ 0.010s]
finished. total time: 0.010s
archive does not contain 'boot.sig'
archive does not contain 'recovery.sig'
failed to allocate 1778160592 bytes
error: update package missing system.img
Press any key to exit...
The Following 2 Users Say Thank You to missime For This Useful Post:
Old 09-02-2015, 20:31   #7 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Try file from here
Extract nd flash manually 1 by 1
Old 10-06-2015, 07:41   #8 (permalink)
Member: 2386502
Thanks Meter: 6
Good post, thanks for sharing.
The Following 2 Users Say Thank You to poonam9898 For This Useful Post:
Old 12-19-2015, 12:14   #9 (permalink)
Member: 2025275
Thanks Meter: 71
Nice work i'm going to add this in Cloud_Commander.
You can find it here http://forum.gsmhosting.com/vbb/f606.../#post11486766
The Following 2 Users Say Thank You to KENKITT For This Useful Post:
Old 03-31-2016, 18:09   #10 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 163
Question Nexus 6 (by Motorola) , XT1100, Android 6.0.1, MMB29V with FRP
Nexus 6 (by Motorola) , XT1100, Android 6.0.1, MMB29V, now is locked with FRP
is it possible to downgrade ?
i intend to use this file : shamu-lmy47i-factory-c8afc588.tgz
here is full getvar info :
C:\AndroidADB>fastboot getvar all
(bootloader) version: 0.5
(bootloader) version-bootloader: moto-apq8084-71.15
(bootloader) product: shamu
(bootloader) board: shamu
(bootloader) secure: yes
(bootloader) hwrev: 0x83A0
(bootloader) radio: 0x7
(bootloader) emmc: 32GB Sandisk REV=07 PRV=01 TYPE=57
(bootloader) ram: 3072MB Hynix S8 SDRAM DIE=6Gb
(bootloader) cpu: APQ8084 ES1.1
(bootloader) serialno: ZX1GXXXXXX
(bootloader) cid: 0x00DE
(bootloader) channelid: 0x00
(bootloader) uid: 289B1C0111000000000000000000
(bootloader) unlocked: no
(bootloader) securestate: locked
(bootloader) iswarrantyvoid: yes
(bootloader) mot_sst: 2
(bootloader) max-download-size: 536870912
(bootloader) reason: Volume down key pressed
(bootloader) imei: 3554700XXXXXXXX
(bootloader) meid:
(bootloader) date: 01-10-2015
(bootloader) sku: XT1100
(bootloader) iccid:
(bootloader) cust_md5:
(bootloader) max-sparse-size: 268435456
(bootloader) current-time: "Thu Jan 29 4:33:49 UTC 2015"
(bootloader) ro.build.fingerprint: none
(bootloader) ro.build.version.full: none
(bootloader) ro.build.version.qcom: none
(bootloader) version-baseband: D4.01-9625-05.32+FSG-9625-02.109
(bootloader) kernel.version: none
(bootloader) sdi.git: git=MBM-NG-V71.15-0-gf291c61
(bootloader) sbl1.git: git=MBM-NG-V71.15-0-g60ea7e6
(bootloader) rpm.git: git=MBM-NG-V71.15-0-g18b261e
(bootloader) tz.git: git=MBM-NG-V71.15-0-ge5920ce
(bootloader) aboot.git: git=MBM-NG-V71.15-0-g96f7faf
(bootloader) partition-type:modem: raw
(bootloader) partition-type:metadata: raw
(bootloader) partition-type:sbl1: raw
(bootloader) partition-type:sdi: raw
(bootloader) partition-type:sec: raw
(bootloader) partition-type:ddr: raw
(bootloader) partition-type:aboot: raw
(bootloader) partition-type:rpm: raw
(bootloader) partition-type:utags: raw
(bootloader) partition-type:tz: raw
(bootloader) partition-typeadA: raw
(bootloader) partition-type:sbl1bak: raw
(bootloader) partition-type:abootBackup: raw
(bootloader) partition-type:rpmBackup: raw
(bootloader) partition-type:utagsBackup: raw
(bootloader) partition-type:tzBackup: raw
(bootloader) partition-type:versions: raw
(bootloader) partition-type:frp: raw
(bootloader) partition-type:mdm1m9kefs1: raw
(bootloader) partition-type:mdm1m9kefs2: raw
(bootloader) partition-type:mdm1m9kefs3: raw
(bootloader) partition-typeadB: raw
(bootloader) partition-type:sp: raw
(bootloader) partition-type:keystore: raw
(bootloader) partition-type:logs: raw
(bootloader) partition-typeersist: raw
(bootloader) partition-type:mdm1hob: raw
(bootloader) partition-type:mdm1dhob: raw
(bootloader) partition-type:cid: raw
(bootloader) partition-type:logo: raw
(bootloader) partition-type:misc: raw
(bootloader) partition-typeadD: raw
(bootloader) partition-type:mdm1m9kefsc: raw
(bootloader) partition-type:ssd: raw
(bootloader) partition-type:recovery: raw
(bootloader) partition-type:kpan: raw
(bootloader) partition-type:boot: raw
(bootloader) partition-type:cache: ext4
(bootloader) partition-typeem: raw
(bootloader) partition-typeadC: raw
(bootloader) partition-type:system: raw
(bootloader) partition-type:userdata: ext4
(bootloader) partition-size:modem: 0x0000000007000000
(bootloader) partition-size:metadata: 0x0000000001000000
(bootloader) partition-size:sbl1: 0x0000000000060000
(bootloader) partition-size:sdi: 0x000000000000e000
(bootloader) partition-size:sec: 0x0000000000004000
(bootloader) partition-size:ddr: 0x0000000000008000
(bootloader) partition-size:aboot: 0x0000000000100000
(bootloader) partition-size:rpm: 0x0000000000040000
(bootloader) partition-size:utags: 0x0000000000080000
(bootloader) partition-size:tz: 0x000000000007d000
(bootloader) partition-sizeadA: 0x000000000040f000
(bootloader) partition-size:sbl1bak: 0x0000000000060000
(bootloader) partition-size:abootBackup: 0x0000000000100000
(bootloader) partition-size:rpmBackup: 0x0000000000040000
(bootloader) partition-size:utagsBackup: 0x0000000000080000
(bootloader) partition-size:tzBackup: 0x000000000007d000
(bootloader) partition-size:versions: 0x0000000000001000
(bootloader) partition-size:frp: 0x0000000000080000
(bootloader) partition-size:mdm1m9kefs1: 0x0000000000100000
(bootloader) partition-size:mdm1m9kefs2: 0x0000000000100000
(bootloader) partition-size:mdm1m9kefs3: 0x0000000000100000
(bootloader) partition-sizeadB: 0x0000000000100000
(bootloader) partition-size:sp: 0x0000000001000000
(bootloader) partition-size:keystore: 0x0000000001000000
(bootloader) partition-size:logs: 0x0000000000200000
(bootloader) partition-sizeersist: 0x0000000002000000
(bootloader) partition-size:mdm1hob: 0x0000000000040000
(bootloader) partition-size:mdm1dhob: 0x0000000000008000
(bootloader) partition-size:cid: 0x0000000000020000
(bootloader) partition-size:logo: 0x0000000000800000
(bootloader) partition-size:misc: 0x0000000000100000
(bootloader) partition-sizeadD: 0x0000000000278000
(bootloader) partition-size:mdm1m9kefsc: 0x0000000000000400
(bootloader) partition-size:ssd: 0x0000000000002000
(bootloader) partition-size:recovery: 0x0000000001004000
(bootloader) partition-size:kpan: 0x00000000008e0000
(bootloader) partition-size:boot: 0x0000000001000000
(bootloader) partition-size:cache: 0x0000000010000000
(bootloader) partition-sizeem: 0x0000000004000000
(bootloader) partition-sizeadC: 0x0000000000100000
(bootloader) partition-size:system: 0x0000000080000000
(bootloader) partition-size:userdata: 0x00000006a13e0000
(bootloader) qe:
(bootloader) ro.carrier: unknown
(bootloader) dm-verity-state: Not Supported
all: listed above
finished. total time: 0.125s
thanks
The Following User Says Thank You to nbkappa For This Useful Post:
Old 03-31-2016, 19:27   #11 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 163
Question
it seems Nexus 6 cannot be downgraded, not even to 6.0...
flashing error : bootloader is LOCKED
bootloader CANNOT be unlocked without OEM switch in Developer Settings
and my phone is in FRP state, and tapping 7 times on Build Number is disabled...
any ideea ?
thanks
The Following 2 Users Say Thank You to nbkappa For This Useful Post:
Old 04-02-2016, 07:44   #12 (permalink)
Member: 2370992
Sonork: 1663758:NAZEEM
Thanks Meter: 2
moto G3
guys any body know how to remove frp solution ,,,,,,
The Following 2 Users Say Thank You to NAZEEM007 For This Useful Post:
Old 04-24-2016, 15:25   #13 (permalink)
aslam hossain's Avatar
Member: 2179298
Sonork: 100.1660353.Aslam
Thanks Meter: 215
User Media - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
The Following 3 Users Say Thank You to aslam hossain For This Useful Post:
Old 04-28-2016, 13:12   #14 (permalink)
Member: 2179298
Thanks Meter: 215
Old 12-10-2016, 08:36   #15 (permalink)
Member: 2647006
Thanks Meter: 2
Its really help me. Thanks a lot...
The Following 2 Users Say Thank You to verhumir For This Useful Post:
Page generated in 0.27704 seconds with 8 queries
