Patch to fully enable GSM on Motorola Verizon CDMA phones <======== How to and Patch to fully enable GSM on Motorola Verizon CDMA phones with Android ! If you have a Motorola Verizon Global Phone for CDMA Network and you want correctly use it on GSM Network than you have to edit the build.prop file to fully enable the GSM and you have to set APNs to use 3g data. This guide and this patch are only for non US users. To fully enable the GSM you must edit the build.prop with correct settings, here a lot of lines that could be edited: Quote:
You can install the patch on every AOSP ROM, on every Stock Rom and on every Android version. Available Version: Patch to enable GSM on Verizon CDMA Android Phones v1.5 How to install the patch:
The patch should work on every Verizon CDMA Phones and it will enable fully the GSM, for now it has been tested and it will most certainly work on these models:
Wbr, bappy |
do you have a root metod for xt912, my phone but it is on mandaring or japanes language. i want do this on english, if it is posible. BR |
this work for unlock those models and use GSM of any carrier???? Motorola Droid 4 xt894 Motorola Droid Razr xt912 Motorola Droid Razr Maxx xt912 Motorola Droid Razr M xt907 Motorola Droid Razr HD xt926 |
There's a more easy way with Radiocomm software..........! |
Why would anyone do this -- GSM is 2G where CDMA is 3G/4G faster data rate. |
Re: Patch to fully enable GSM on Motorola Verizon CDMA phones As far as I am concerneed I think this is a patch to fully enable GSM on every Stock Rom, on every AOSP Rom and on every Android version. If you have a Verizon Global Phone for CDMA Network and you want correctly use it on GSM Network than you have to edit the build. |
i'l try... can 3G more faster? |
is good to use 3G wcdma! |
need cwm file for xt875 its urgent thanks in advance :) |
Will this patch work on moto x verizon |
i have an LG VS870 4G Verizon, i applied this patch from xda [PATCH][GUIDE] Patch to fully enable GSM on … | Android | XDA Forum but nothing happens and when i dial #*#*4636*#*# nothing happend too, somone can help me ? thnx |
