Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Android based
Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help
Old 10-19-2013, 08:40   #1 (permalink)
Cheater -Don't Deal with him-
Member: 1390802
Thanks Meter: 1,097
Patch to fully enable GSM on Motorola Verizon CDMA phones <========
How to and Patch to fully enable GSM on Motorola Verizon CDMA phones with Android !
If you have a Motorola Verizon Global Phone for CDMA Network and you want correctly use it on GSM Network than you have to edit the build.prop file to fully enable the GSM and you have to set APNs to use 3g data.
This guide and this patch are only for non US users.
To fully enable the GSM you must edit the build.prop with correct settings, here a lot of lines that could be edited:
telephony.lteOnCdmaDevice=0
persist.ril.modem.mode =2
ro.telephony.default_network=3
ro.mot.eri=0
ro.mot.phonemode.vzwglobalphone=0
persist.radio.vzw.cdma.mdn=deleted
ro.telephony.gsm-routes-us-smsc = 0
persist.radio.ap.phonetype=1
persist.radio.lte.mm.disable=1
persist.ril.features = 0x102
ro.HorizontalBUA=false
ro.HorizontalVVM=false
ro.mot.phonemode.vzw4gphone=0
ro.mot.lte_on_cdma=0
ro.telephony.ril.v3=signalstrength,skipbrokendatac all,writeaidonly
telephony.rilV7NeedCDMALTEPhone=false
ro.cdma.subscribe_on_ruim_ready=false
ro.com.google.clientidbase.ms=android-motorola
ro.com.google.clientidbase.am=android-motorola
ro.com.google.clientidbase.yt=android-motorola
With correct lines you will enable on every Rom:
  • fully GSM
  • SMS
  • MMS
  • 3G Data
  • USSD Code
If you wont you can install the patch here attached; The patch will automatically edit your build.prop with corrects lines for your terminal and will add a correct list of GSM APNs.
You can install the patch on every AOSP ROM, on every Stock Rom and on every Android version.
Available Version:
Patch to enable GSM on Verizon CDMA Android Phones v1.5
How to install the patch:
  1. Copy the .zip file to the external memory or memory card
  2. Reboot your phone and enter on Safestrap
  3. From the Install menu select the .zip file and instal withotut signature verification on your Rom
After installing the patch to optimize the GSM go into the hidden menu Testing typing the code *#*#4636#*#* and you have to set: Phone info -> Set prefered network type -> GSM auto (PRL).
The patch should work on every Verizon CDMA Phones and it will enable fully the GSM, for now it has been tested and it will most certainly work on these models:
  • Motorola Droid 4 xt894
  • Motorola Droid Razr xt912
  • Motorola Droid Razr Maxx xt912
  • Motorola Droid Razr M xt907
  • Motorola Droid Razr HD xt926
Wbr,
bappy
The Following 9 Users Say Thank You to ..::MOBILEPARK::.. For This Useful Post:
Old 10-19-2013, 08:57   #2 (permalink)
Member: 1390802
Thanks Meter: 1,097
here the .zip file verizon_cdma_to_gsm_patch_v1.5_by_mentor.zip
Wbr,
bappy
The Following 6 Users Say Thank You to ..::MOBILEPARK::.. For This Useful Post:
Old 11-09-2013, 16:31   #3 (permalink)
Member: 1067814
Sonork: 100.1618982
Thanks Meter: 80
do you have a root metod for xt912, my phone but it is on mandaring or japanes language.
i want do this on english, if it is posible.
Old 12-14-2013, 18:25   #4 (permalink)
Member: 1204194
Thanks Meter: 3
this work for unlock those models and use GSM of any carrier????
Old 12-16-2013, 13:17   #5 (permalink)
guru4gsm's Avatar
Member: 517316
Thanks Meter: 185
There's a more easy way with Radiocomm software..........!
Old 12-16-2013, 13:25   #6 (permalink)
Member: 1762185
Thanks Meter: 53
Why would anyone do this -- GSM is 2G where CDMA is 3G/4G faster data rate.
Old 12-25-2013, 05:45   #7 (permalink)
Member: 2091143
Thanks Meter: 4
it meant wcdma is 3g
Old 01-17-2014, 07:56   #8 (permalink)
Member: 2095964
Re: Patch to fully enable GSM on Motorola Verizon CDMA phones
As far as I am concerneed I think this is a patch to fully enable GSM on every Stock Rom, on every AOSP Rom and on every Android version. If you have a Verizon Global Phone for CDMA Network and you want correctly use it on GSM Network than you have to edit the build.
Old 01-17-2014, 09:20   #9 (permalink)
Member: 2103307
Thanks Meter: 2
i'l try...
can 3G more faster?
The Following User Says Thank You to unlockcc For This Useful Post:
Old 01-19-2014, 08:38   #10 (permalink)
Member: 2102324
Old 01-19-2014, 08:48   #11 (permalink)
Member: 2103282
is good to use 3G wcdma!
Old 01-20-2014, 04:53   #12 (permalink)
Member: 2103307
Thanks Meter: 2
Old 01-30-2014, 05:56   #13 (permalink)
ashad77's Avatar
Member: 1525116
Sonork: not yet ;)
Thanks Meter: 63
need cwm file for xt875
its urgent
thanks in advance
Old 05-17-2014, 19:47   #14 (permalink)
Member: 2161831
Thanks Meter: 9
Will this patch work on moto x verizon
Old 07-26-2014, 03:02   #15 (permalink)
Member: 809544
Thanks Meter: 2
i have an LG VS870 4G Verizon, i applied this patch from xda [PATCH][GUIDE] Patch to fully enable GSM on &hellip; | Android | XDA Forum but nothing happens and when i dial #*#*4636*#*# nothing happend too, somone can help me ? thnx
Page generated in 0.43905 seconds with 7 queries
