Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Android based
Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help
Old 10-12-2016, 05:29   #1 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,653
XT1548 CDMA / GSM bands Enable
Motorola G Third Generation 2015 (MOTXT1548)
Verizon CDMA network or Virgin Mobile
Codename: Motorola Surnia or Osprey
This is a temporary procedure, with each system upgrade, will have to re-apply the changes.
Enable USB debugging and accessed via adb (Android Debug Bridge)
Access via ADB
Access via Android Debug Bridge is quite simple, executing:
./adb devices
List of devices attached
TA104098CI device
Simply enter a console terminal:
adb shell
We're really not unlock anything, the team is native quad and comes with SIM unlocked, right ?, roaming, Verizon has begun to allow their customers to use their equipment in GSM networks outside the United States.
They simply indicate that the terminal will use GSM networks for our team, for this:
1. We turn off the terminal and enter a SIM card (micro-SIM) from the telephone operator of our taste (in my case: Movistar Venezuela).
2.Colocamos equipment in Airplane mode:
We entered a shell of ADB:
adb shell
And execute the following 3 commands:
settings put global preferred_network_mode 9
settings put global preferred_network_mode1 9
settings put global preferred_network_mode2 9
Each is a separate command; the mean, each enabled in the "preferred networks" each of the modes (CDMA, LTE and GSM), allowing look at the phone configuration.
NOTE: As I stated above, this is a "temporary" step, since not using root does not rewrite the settings.db and therefore, there remains a phone upgrade.
We turn off the computer
We turn on the power and ready.
To verify, you can request the information menu:
* # * # 4636 # * # *
(4636 = I N F O)
And there, in "Network information" seeking radio mode by default (Default: TD-SCDMA, LTE, CDMA, EvDO GSM / WCDMA)
Note: If the menu info is not working (I have reported some cases) can go to Google Play Market and download an application called "Network" (Philipp Mangelow) which is simply a shortcut to INFO menu.
Note 2: Digitel 4G LTE network is incompatible with the bands of this equipment.
Note 3: As a team VERIZON, the DB is incomplete APNs must configure the NPC (s) operator (s) to be used in the terminal to access the data plan.
The Following 3 Users Say Thank You to gcceleghg For This Useful Post:
Old 10-12-2016, 05:36   #2 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,653
Permanent Process:
Unlock the Bootloader
Install KingoRoot
When the finished device, authorize "adb" to root access.
Finally, connect to a root console: (surnia / osprey)
./adb shell
shell @ surnia_cdma: / $ su
surnia_cdma root @: / #
And there run:
pm clear com.android.providers.telephony
Thus, they are clean configurations phone, restart the terminal
reboot
or adb reboot
And again execute the above procedure:
Done!
Old 12-23-2017, 08:25   #3 (permalink)
Member: 2419215
Thanks Meter: 3
not working. both root method and without root method
Old 01-17-2019, 09:52   #4 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 419
Originally Posted by gcceleghg View Post
Permanent Process:
Install KingoRoot
./adb shell
And there run:
reboot
or adb reboot
Done!
@gcceleghg
Respected Sir
And All Friends
I Need QCN Please From Working Fone
I Will Be Grateful To All Of You
Thanks Anticipation
Page generated in 0.23866 seconds with 7 queries
