Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
07-27-2017, 13:59 | #2 (permalink) |
Junior Member Join Date: Mar 2014 Location: Teresina, Brazil
Member: 2157735 Status: Offline Thanks Meter: 3 | From the first patch, I saw something like that, Command being executed in fastboot mode, deleting the frp partition, which is actually present, if it is to query with the "getvar all" command, What remains is to know how and with which tool was made (and if in fact it is real). We can not but emphasize that the bootloader can be unlocked, and this is just somebody's litany. Many possibilities |
07-27-2017, 14:29 | #3 (permalink) |
Freak Poster Join Date: Jun 2010 Location: Brazil
Member: 1326244 Status: Offline Thanks Meter: 5 | I was also in doubt about the legitimacy of the process, but a friend assured that the process is true. I have done some tests and realized that some commands used in the above process are not enabled in the OEM, and as it is with the lock of the FRP has no way to unlock the bootloader. I'm researching to try to figure out how this can be done. I accept suggestions. Sorry for the bad English! |
07-27-2017, 14:49 | #4 (permalink) |
Member: 2157735 Status: Offline Thanks Meter: 3 | Yes, I always thought about the possibility of a forced bootloader unlock, as it can be done in some Xiaomi, which is also Qualcomm, but I do not know, motorola has a lot of security. Please wait Yes, yes, studying. And anyway, one hour or another appears. |
08-03-2017, 22:44 | #9 (permalink) |
Member: 2157735 Status: Offline Thanks Meter: 3 | No, my friend, I just imagined it, but I'm not getting anything like that. This would be possible if you could put it in qdloader mode (hs-usb) and recording an unlocked firehose. But I find it almost impossible to do that, rs. So let's wait and see. Enviado de meu LG-H840 usando Tapatalk |
08-03-2017, 22:53 | #10 (permalink) | |
Junior Member Join Date: Jul 2008
Member: 820255 Status: Offline Thanks Meter: 2 | frp Quote:
09-15-2017, 12:58 | #13 (permalink) |
Member: 1326244 Status: Offline Thanks Meter: 5 | I discovered some news. The process to remove this FRP is done by motoservice 3.1.0 but it is ugly by the Kill Switch but to use this tool you have to read the device information as I use the motoservice in offline mode I can not do this but I hope some friend of the forum find some solution for this. |
