Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
10-05-2018, 14:06 | #3 (permalink) | |
Insane Poster Join Date: Nov 2006 Location: Goiás - Brasil Age: 39
Member: 397772 Status: Offline Sonork: 5561995554600 Thanks Meter: 97 | Quote:
Does this ROM repair touch error after upgrading to 8.1.0? | |
10-05-2018, 14:54 | #4 (permalink) | |
Freak Poster Join Date: Jun 2010 Location: Brazil
Member: 1326244 Status: Offline Thanks Meter: 5 | Ti try this Quote:
The Following User Says Thank You to Cretino1 For This Useful Post: |
10-05-2018, 17:32 | #5 (permalink) |
Freak Poster Join Date: Dec 2011 Location: Brazil
Member: 1705083 Status: Offline Thanks Meter: 25 | The procedure is to replace the front with an original or download this firmware that Resident_Evil left and test to see if it works. Last edited by rmarconcini; 03-27-2019 at 16:24. Reason: Not english post part removed |
10-14-2018, 14:10 | #6 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Pb - BRAZIL
Member: 689942 Status: Offline Thanks Meter: 312 | Ps. : Staff the forum is in English, if they write in Portuguese they will be breaking the rules and they can be banned. Write the flash "MONTANA_NPP26.102-49_cid50_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml" via adb using the commands below. fastboot oem fb_mode_set fastboot flash partition gpt.bin fastboot flash bootloader bootloader.img fastboot flash logo logo.bin fastboot flash boot boot.img fastboot flash recovery recovery.img fastboot flash dsp adspso.bin fastboot flash oem oem.img fastboot flash system system.img_sparsechunk.0 fastboot flash system system.img_sparsechunk.1 fastboot flash system system.img_sparsechunk.2 fastboot flash system system.img_sparsechunk.3 fastboot flash system system.img_sparsechunk.4 fastboot flash system system.img_sparsechunk.5 fastboot flash system system.img_sparsechunk.6 fastboot flash system system.img_sparsechunk.7 fastboot flash system system.img_sparsechunk.8 fastboot flash system system.img_sparsechunk.9 fastboot flash modem NON-HLOS.bin fastboot flash fsg fsg.mbn fastboot erase cache fastboot erase userdata fastboot erase customize fastboot erase clogo fastboot oem fb_mode_clear fastboot flash logo logo.bin fastboot reboot When the device connects, install the security patch via wifi, and then disable the updates because upgrading to android 8.1 will hang the touch againi. |
The Following User Says Thank You to celltellpb For This Useful Post: |
10-14-2018, 17:38 | #7 (permalink) | |
