Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
06-21-2012, 23:04 | #6 (permalink) |
Freak Poster Join Date: Aug 2010 Location: On the internet Age: 95
Member: 1383120 Status: Offline Sonork: 100.1612024 Thanks Meter: 18 | try this Motorola RAZR XT910 Unlocking Instructions: 1. Input a non accepted simcard (This model requires a Micro Simcard) 2. Motorola Phone will display enter "Sim network unlock PIN" 3. Input the unlock code that was emailed to you 4. Phone will display "Network Unlock Successful" |
06-22-2012, 00:35 | #7 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: Monrovia
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | Quote:
06-22-2012, 08:02 | #8 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In a point from Universe! Age: 40
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | XT912 is for Verizon and it has only cdma band enabled in it and the best is that is not locked; When you insert a nonVerizon sim card you get the message: "This SIM card is from an unknown source!" To make it work just download Radiocomm 11.12.2 from here: RadioComm_v11.12.2_Install.zip , after this connect the phone to the pc and select pc mode. In radiocomm go to ma/common/mdm 6x00 go to settings/usb/pst usb drivers switch to ftm common 1 and wait for the phone to make it purple or green on the upper side in NVAcces got to value 1877 NV_RF_BC_CONFIG_I Read the value from the device and after that replace first 16 digits with: 8703E804000200 write data back and restart. Insert an gsm card into the phone and the gsm band will be enabled The solution that I explained here already is posted on xda forum; all the credits go to them I just only apply it with succes on several xt912. Regards! |
The Following 7 Users Say Thank You to Burebista For This Useful Post: |
06-25-2012, 19:49 | #11 (permalink) |
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | in nv access after i select the value, when i pressing the read button its shwoing like this Sending 'NVRead' command with data '5507000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000000' to the radio... Sent to radio: 26550700000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000000021CC7E Returned from radio: NVRead ==>FAILED Driver answer ==> -256 Error Description ==> PST: Handle to device is invalid - no device present Time to execute command: 0 seconds. Command timeout set to : 15 seconds. and read button colour change to red plz let me know where i doing mistake????? |
07-10-2012, 02:46 | #14 (permalink) | |
No Life Poster Join Date: Mar 2006
Member: 240043 Status: Offline Thanks Meter: 78 | Quote:
07-10-2012, 08:04 | #15 (permalink) |
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | Hello, if you did exactly like's here, surelly will be OK. Just go at the networks in the phone menu and check if the gsm band is activated. Regards! On some phone you'll get the same error message but will work without problems. |
The Following 2 Users Say Thank You to Burebista For This Useful Post: |
G.M. 's GSM Links Nokia Siemens Trium Motorola Sagem | GM | GSM Mobile Links | 0 | 06-18-2000 09:04 |
Updated site... Motorola BOX, Nokia Clip... | mihut | GSM Mobile Links | 0 | 05-29-2000 02:52 |
I have unlcoker for 51/61/32 for all new version for exchange Motorola 3*88 unlocker! | MC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-14-1999 13:02 |
Soft for Motorola with cable... | florin_m | GSM Mobile Links | 3 | 10-11-1999 14:44 |
Ericsson-Motorola-Siemans unlock solutions | dave | GSM Mobile Links | 0 | 08-27-1999 19:46 |
