Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Windows & MeaMo/MeeGo based
Nokia Windows & MeaMo/MeeGo based N900,N9,N950,700,710,N800,800,920,925 etc all linux and WP phones flashing & unlocking only here
Old 07-03-2013, 12:52   #1 (permalink)
Member: 472378
Sonork: 100.1597506
Thanks Meter: 292
nokia 520 Hard Reset done
nokia 520 Hard Reset done simpal step
Hard Key Combination:
Use this option if your device is locked and you don't know the code.
Note: Make sure that your Nokia Lumia is turned off.
Step 1. Press and hold the power key until it vibrates then release.
Step 2. Press and hold the down key volume. If the exclamation mark will be shown on the screen, you can now release the button.
Step 3. You need to input these key combination:
Volume Up > Volume Down > Power > Volume Down.
Your phone will reset and will boot up automatically. This might take a several minutes.
The Following 2 Users Say Thank You to ..::Rana Bilal::.. For This Useful Post:
Old 08-31-2013, 16:18   #2 (permalink)
Member: 1682075
Thanks Meter: 17
last step i can ander stand sorry
Old 09-01-2013, 06:42   #3 (permalink)
Member: 43940
Thanks Meter: 27
press 1 time volume up
1 time volume down
1 time power
1 time volume down
Old 10-03-2013, 08:38   #4 (permalink)
niaz muhammad's Avatar
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
Nokia Lumia 520 hard reset Windows Phone 7
1. Turn off your Lumia 520 phone.
2. Press and hold the Volume down and Camera keys.
3. Press and hold the Power key.
4. When you feel the phone vibrates, release the power key, but keep pressing the volume down and camera keys, until the phone reboots. All data will be lost!
Nokia Lumia 520 hard reset Windows Phone 8
Old 11-13-2013, 16:56   #5 (permalink)
Member: 67260
Thanks Meter: 146
HArd Reset Done ... lumia 520
HArd Reset Done ... lumia 520..
Old 02-17-2014, 15:33   #6 (permalink)
Member: 1291309
Thanks Meter: 58
1.Power off your phone
2.Press power button and after phone vibrates once press volume down until you will see exclamation sign on the screen
3.Press in this order:volume up
volume down
power
volume down
4.Wait until format ends and the phone restarts
That's it
100000%
The Following User Says Thank You to ROhan464 For This Useful Post:
Old 02-17-2014, 15:38   #7 (permalink)
Member: 1291309
Thanks Meter: 58
1st power of mobile
2nd power on mobile than vibrate and pres vol dowun phone goin on boot mood ok
vibrate hote he volim dow buton presh karna hai boot mood men chal jaye ga
2nd fhir boot mood men ane k baad sab se phale vol up fhir vol down fhir vol power button fhir vol down set going on fromatting mood yesab button 1 1 kar k dabate jao step by step set 101 % unlocked enjoy and thanks
https://www.youtube.com/watch?v=LtWR6en5dC4#t=193
Old 02-28-2014, 09:05   #8 (permalink)
Member: 1226213
Thanks Meter: 7
Nokia lumia hard reset Done 100000%
Step 1
1. press and hold the power key
2. phone vibrates (release the power key)
3. press and hold the V- key
4. exclamation mark is shown on he screen (release the V- key)
Step 2
Input the key combination:
1. V+
2. V-
3. Power
4. V-
Step 3
The phone will reset and boot up automatically.
The Following 4 Users Say Thank You to danushka1987 For This Useful Post:
Old 03-05-2014, 11:45   #9 (permalink)
Member: 784847
Thanks Meter: 45
Old 04-23-2014, 07:27   #10 (permalink)
Member: 2156106
this buttor order is not working for me
I've tried lot of times but it is starting normal mode
what to do
please help me somebody
Old 04-29-2014, 12:52   #11 (permalink)
Member: 1682308
Sonork: ahadalami
Thanks Meter: 14
this method wont work for u i think ur using wp 8
what to do
br this method wont work in wp8 it works in wp7
Old 05-06-2014, 14:53   #12 (permalink)
Member: 1376591
what to do
must check your volume bottions
Old 05-08-2014, 11:08   #13 (permalink)
Member: 2015096
Thanks Meter: 7
sir how to network unlock nokia 520.2? thankzz advance
Old 06-28-2014, 16:08   #14 (permalink)
javaflasher's Avatar
Member: 1892139
Thanks Meter: 56
1. Turn the power Off.
2. Press and hold the Volume down and connect the charger or the USB cable with PC, for about 8 seconds, you will see an exclamation mark (!) on the screen. Note: If you do not press any of the following keys, then the phone wp8 will starts boot normally.
Then press the keys in this exact order:
1. Volume up
2. Volume down
3. Power
4. Volume down
br
The Following User Says Thank You to javaflasher For This Useful Post:
Old 07-15-2014, 08:03   #15 (permalink)
Member: 2071735
Thanks Meter: 9
nokia lumia blue screen problem solve hard reset your phone problem solve......
Page generated in 0.18777 seconds with 8 queries
