Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Windows & MeaMo/MeeGo based
Nokia Windows & MeaMo/MeeGo based N900,N9,N950,700,710,N800,800,920,925 etc all linux and WP phones flashing & unlocking only here
Old 12-13-2012, 12:20   #16 (permalink)
Member: 156994
mobile tech !! if u find any source for real working unlock code please let me know iam also searching . will let u know if i find something
Old 12-23-2012, 15:35   #17 (permalink)
mobile tech!!'s Avatar
Member: 829776
Sure will, i,m still on it friend
Old 12-28-2012, 14:58   #18 (permalink)
Member: 829776
lumia 900 wrong code work around
I bought a Nokia Lumia 900 that was tied to AT&T. I got an unlock code from AT&T, but it didn't work and I was down to 5 attempts. Thanks to some guys over at forum.XDA-Developers.com, I discovered this workaround, which involves entering your "Incorrect" 8-digit unlock code until you apparently run out of errors. The phone then requests a PUK code, which is actually the unlock code you were given.
i got this off you tube and it work 1000000000000000%%
The Following User Says Thank You to mobile tech!! For This Useful Post:
Old 01-07-2013, 10:50   #19 (permalink)
Member: 462166
Thanks it works like charm
Old 02-03-2013, 22:28   #20 (permalink)
sultansaga's Avatar
Member: 194936
Sonork: 100.1616223
Contact me on Sonork or Skype
For lumia AT&T
Old 03-13-2013, 13:46   #21 (permalink)
Member: 1439040
Sonork: 100.1624808
Same problem with me, i inserted ##782# but nothing changed, i have the code ready but i cann't get my phone work, please help!!! it keeps dispaying "The SIM card is missing or invalid. You can still make emergncy calls if your mobile operator supports it" Plz give solution,... have tried many solutions
-reset the unit
-insert att sim card
but nothing, the phone original for ATT carrier
Old 03-13-2013, 16:52   #22 (permalink)
Member: 759190
someone try this? successfully?
Old 03-13-2013, 22:21   #23 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Hi,
Yeah, this tested... However, you can always reset the counters for Lumia 610, 710 and 800 by flashing firmware - tested.
Old 04-07-2013, 13:58   #24 (permalink)
Member: 263005
enter unlock code 8 times ,now phone shows puk blocked and then enter code ,PHONE IS UNLOCKED !!!! tested by me 100%
The Following User Says Thank You to alimuamin For This Useful Post:
Old 04-10-2013, 11:33   #25 (permalink)
Abzal's Avatar
Member: 19032
-reset the unit
Same problem, has solution for reset counters?
Old 04-10-2013, 12:07   #26 (permalink)
Member: 643472
Sonork: 100.96901
Hi,
Unfortuneately, reset counter by flashing doesn't work on Lumia 900.
Old 04-10-2013, 12:30   #27 (permalink)
Abzal's Avatar
Member: 19032
it makes sense to wait solution or just play with it like a toy?
Old 05-08-2013, 00:00   #28 (permalink)
wilmer's Avatar
Member: 392589
Sonork: 1597152
so no solution for this problem lumia 900 sim not detected,
Old Yesterday, 05:09   #29 (permalink)
Member: 345808
oppen the mobile be care full its smply problem cheak the sim tray its broken
Page generated in 0.15206 seconds with 10 queries
